Old 02-22-2015, 07:46 PM   #1
Hoahao
Drives: 2014 Monogram Hot Lava
Dead battery!?!
Left the FRS in the garage for 2 days and wouldn't even turn over this morning. Got a lot of flashing from every light on the dash. Hmm... throw a trickle charger on it and let it sit whilst I do a little snow shoveling. 3 hours later it fires up like it's supposed to. Heated seat was off, heater was off so the sucker would warm up quicker, dome light off. Only thing left on was the cd player.
Proceeded to cruise around and it fired up when I turned it on and off a couple of times when I got back home. Will leave on the trickle charger tonight and have them check the system when I go in for an oil change unless it really leaves me standing before that.
Hoahao is offline   Reply With Quote
Old 02-22-2015, 10:23 PM   #2
BRZnut
Drives: BRZ DGM Limited
How old is the battery? Any after market electronics? Temp of your garage?
Old 02-23-2015, 10:39 AM   #3
Hoahao
Garage unheated so the temp was probably about 25 degrees. Car was built Spring of '14 and sat at the dealers unti I bought it mid October. No after market electronics.
If what I've read here is accurate, letting the battery go flat weakens it. I suspect at the dealers it was left unattended for months at a time before I bought it. Course, something might be wrong with the charging system too.
Old 02-23-2015, 10:46 AM   #4
Left mine for 3 days during the coldest weather we have had (-25) and it started on the first crank no problem.
There do seem to be a handful of guys that have had battery issues on here though. Take it in and have a draw test done and you may find that you have joined that exclusive club!
Old 02-23-2015, 12:20 PM   #5
FRSBRZGT86FAN
FRSBRZGT86FAN's Avatar
The battery sounds like its at the end of it's life prematurely. I would say if you have a multimeter perform a parasitic draw test and tell us the load on the car when off, but I think you should go to a dealer who can load test the charging system and battery quite quickly and for free under warranty.
Old 02-23-2015, 05:06 PM   #6
billwot
Drives: '11 Cayman , '14 Camry, '11 Tacoma
Mine sat for 5 days under a blanket of ice...nighttime temps below 0F.
Started this AM on the first crank.
billwot is offline   Reply With Quote
The Following User Says Thank You to billwot For This Useful Post:
Tcoat (02-23-2015)
Dead battery; starts up in limp mode kilrb Issues | Warranty | Recalls / TSB 15 01-04-2018 03:54 PM
Dead battery. AlanKent BRZ First-Gen (2012+) — General Topics 50 03-31-2015 02:36 AM
Is there any know that how to open the truck when the battery is dead?????? wilson0326 Scion FR-S / Toyota 86 GT86 General Forum 31 07-06-2013 10:24 PM
Dead Battery BUT Honk Horn and it Turns on Car ScionFR-S Issues | Warranty | Recalls / TSB 9 06-11-2013 03:47 PM
Ignorance and a dead battery Red John Issues | Warranty | Recalls / TSB 9 03-02-2013 02:29 PM
