| BRZ First-Gen (2012+) — General Topics All discussions about the first-gen Subaru BRZ coupe |
Drives: '15 Brz Series Blue
TPS light on in cold temp
So lately here in Northern California it has been below freezing when i have woken up to get ready for work and each day (3 days in a row now) when i start my 2015 brz the tps light is on but all tire pressures are within spec and then once it warms up (outside air temp) the tps light goes away.. Thoughts?
#2 |
Drives: 2015 Series.Blue BRZ
When gas is cold, its pressure drops. The air pressure in your tires is directly related to the temperature of the tire. The outside air makes the tire cold and the pressure goes down which turns on the TPS light, but once you start driving they heat up and the pressure rises again to an acceptable level. If the outside temp has been staying pretty low, you probably should add some air into your tires.
| The Following User Says Thank You to Rota For This Useful Post: | Ganthrithor (01-03-2015) |
#3 | |
Yep, that pretty much defines it. Also, the TPS sensors are not set to the exact air pressure required for your tires, but something well below it. Chances are as @Rota says, you probably need air regardless. The cold weather was just enough to make it drop below the sensor level. Of the five cars in my family, 4 have sensors and envariably on the first cold day of Fall, at least half of them need air. The FR-S has needed air every Fall.
Visit my Owner's Journal where I wax philosophic on all things FR-S Post your 86 or see others in front of a(n) (in)famous landmark. What fits in your 86? Show us the "Junk In Your Trunk". |
#4 |
this is what i thought as well. air>gas ratios. it threw me for a loop last night tho when it was cold after dark and dropped down into the 40s and the light never came back on. i have nitrogen in my tires as well so im not sure if i want to add more being that the cold season only lasts about two weeks here in nor cal.
#5 |
Drives: 2015 Asphalt FR-S
It's the temperature drop. When I used to live in the Midwest, I always had to add more air in the tires, and do it more often, in winter.
#6 |
Sarcastic Bastard
Drives: '13 DGM BRZ, '13 Mini, 1999 Blazer
lol @ nitrogen. I'll bet the stealership charged you extra right?
#7 |
Rule of thumb is for every 10 degrees in air temp, tires change by 1 lb. Not sure if this holds true for Nitrogen........
#8 |
#9 | |
#10 |
Drives: Subaru BRZ Series.Blue
I had the same thing happen on my Series.Blue ever morning, just fill it up a pound or two and itll go away.
| FS: BNIB Prosport Guages (Water Temp / Exhaust Gas Temp) | AtlasMick | Interior Parts (Incl. Lighting) | 2 | 03-31-2015 05:47 PM |
| How cold is too cold to seal and wax? | Jertronic | Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) | 3 | 11-01-2013 11:20 AM |
| STRI DSD SLM II Gauges (boost/oil temp/oil press/water temp/egt) BNIB | ziptiedae86 | Interior Parts (Incl. Lighting) | 0 | 10-29-2013 11:50 PM |
| White Smoke cold start up in Cold Weather (turbo cars) | whitefrs | Forced Induction | 17 | 09-25-2013 05:05 PM |
| water temp | driver01 | Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) | 30 | 04-11-2013 02:57 AM |
