Old 12-27-2014, 11:56 PM   #1
RobAus
Drives: 2013 BRZ Limited
Trunk Release Opener not working (wireless key or physical key)
I found the trunk release would not work from dash button, trunk button or wireless key. I took it to the dealer who found the trunk release disable button depressed. Apparently an umbrella tip is the perfect height to press the button if pointed toward the driver side 90 degrees to the rear wheel.
If this occurs save yourself some trouble. Crawl through the split seat and check the button at the bottom driver side of the trunk deck. Trunk release disable is out, trunk release enable is in.
I'm not sure which models this applies to, in this case it is a 2013 BRZ Limited.
RobAus is offline   Reply With Quote
Old 12-28-2014, 01:45 AM   #2
navanodd
Drives: 2013 BRZ Sport-tech WRB
Yeah. They definitely should have thought through the placement of that button a bit better.
As an alternative to crawling in, there is a key hole above the rear license plate, next to the license plate light (you insert the key upwards). If you have push button start, there is a little button on the side of your key fob that releases a key that can be used for opening the trunk or doors.
navanodd is offline   Reply With Quote
Old 12-28-2014, 01:55 AM   #3
86geek
86geek's Avatar
Drives: 2015 FRS Asphalt
My 2015 FRS has the button on the left side of the trunk. Scion sales rep told me about the trunk button.
86geek is offline   Reply With Quote
Old 12-28-2014, 12:02 PM   #4
WhiteFRS69
WhiteFRS69's Avatar
Drives: 2014 Scion FRS
there is a spot for the key to go into the trunk to open it that way as well
on my '14 where the license plate lights are, right to the right of them is where you can put the key into the trunk and unlock it
trunk lid, trunk opener, trunk opening, trunk release
Trunk not working FRS TT Issues | Warranty | Recalls / TSB 22 08-23-2017 12:52 AM
Trunk Release Not Working FRSNewb Issues | Warranty | Recalls / TSB 22 09-05-2014 04:47 PM
Trunk opener button fitcious Scion FR-S / Toyota 86 GT86 General Forum 13 05-13-2014 02:24 AM
trunk release quit working regal Issues | Warranty | Recalls / TSB 4 04-20-2013 11:41 AM
Trunk button not working Jahdai42 Issues | Warranty | Recalls / TSB 4 02-19-2013 09:03 AM
