Old 03-16-2014, 02:17 PM   #1
post_break
Professional Smartass
post_break's Avatar
Drives: White Out FRS
DIY Retrofit Winjet headlights
Everyone loves the Winjet headlights, JDM/10 series headlights for under $500. Well the only problem with them is the light output isn't the best. The cutoff is also kinda crappy when using HIDs. So lets fix that.
What you need:
D2S projectors from morimoto
D2S HID bulbs
HID relay harness if you haven't installed one
I purchased everything from http://www.illuminatinglightworx.com/
So the Winjets use a knock off of the D2S projector. They have a modified bulb connector to use H1 bulbs. Luckily you can very easily replace the projectors that come with the Winjets by purchasing the D2S round projectors from the retrofit source.
These projectors are plug and play. They screw right in, no adapters needed. So how do you get the headlights apart?
Set your oven to 200F and make sure it's stabile. Put the headlight in for 8-9 minutes and grab a screwdriver or panel pryer tool and get to work. You'll need to remove the screws from the headlight before you bake it.
Once you have the new projectors in repeat the process and put the screws back in while it's still hot.
So with that done button her back up and plug your D2S HID's in and you're good to go!
post_break is offline   Reply With Quote
The Following 3 Users Say Thank You to post_break For This Useful Post:
FRSBRZGT86FAN (10-04-2015), NemeGuero (03-28-2014), thatfilipinoguy (03-16-2014)
Old 03-28-2014, 01:52 PM   #2
sero901
sero901's Avatar
Drives: 2014 Scion FRS
Hey, i had a quick question about the winjet lights. I like the black ones but it doesn't look to have the reflector portion for your high beams. can you confirm this? thanks.
sero901 is offline   Reply With Quote
Old 03-28-2014, 03:42 PM   #3
SkAsphalt
Ridge Racerrrrrrrrr
SkAsphalt's Avatar
There is no separate high beam with the winjet, just like the JDM and 10-series lights. The projector does dual duty with low and high beam
Old 03-28-2014, 03:59 PM   #4
Brody602
Drift King
Brody602's Avatar
Drives: '13 Firestorm FR-S 6MT
@post_break a little more detail would be nice, I.E. How you wired in the new projectors to work with the bi-xenon setup?
'13 6MT Firestorm FR-S
Brody602 is offline   Reply With Quote
Old 03-28-2014, 04:28 PM   #5
post_break
post_break's Avatar
The winjets are bixenon from the start. You just need an HID harness with relays.
Basically this guide : http://www.ft86club.com/forums/showthread.php?t=10296
The only difference is that you will be cutting the connector off on one side, and attaching it to the wires that go to the high beam flippers. Super simple.
Old 03-28-2014, 04:29 PM   #6
NemeGuero
Oh awesome! I was wondering if the winjets used the same size stuff as OEM. Excellent.
NemeGuero is offline   Reply With Quote
Old 07-15-2014, 01:13 AM   #7
tonypalomo
Are those 5000k or 6000k? They look amazing!
tonypalomo is offline   Reply With Quote
Winjet headlights fogging up? Frs32907 Cosmetic Modification (Interior/Exterior/Lighting) 23 05-17-2014 02:26 PM
FS: TRS HID Retrofit Headlights for Sale tonystewart Exterior Parts (Aero, Lighting, Etc.) 31 04-15-2014 07:51 PM
Painted Housing Headlights with TRS retrofit The Slow One Exterior Parts (Aero, Lighting, Etc.) 2 01-06-2014 12:24 AM
Custom Purple Winjet and Black Winjet Headlights xclusive_brett Cosmetic Modification (Interior/Exterior/Lighting) 35 12-17-2013 09:28 AM
10 series headlights retrofit with regular frs need help! bdanisi Cosmetic Modification (Interior/Exterior/Lighting) 5 11-21-2013 06:37 PM
