Old 07-15-2017, 10:37 AM   #1
brillo
Drives: 2013 Firestorm FR-S
Why are the rear differential bushings different left from right
Been playing with the EVO diff inserts (anti tramp) bushings and was wondering why the two rear diff bushings are different in terms of shape and bolts. Is that due to the rotation of the crank shaft?
If you only stiffened one of the two, what would happen? Trying to reduce drive train lash when shifting hard but looking to limit NVH.
2013 Firestorm FR-S, MTX, build date 1/13.
brillo is offline   Reply With Quote
Old 07-15-2017, 09:07 PM   #2
bhmax
Drives: 13 BRZ, 17 Focus RS
I feel I'm similar to you in that I'm a bit sensitive to drivetrain lash, but like to limit NVH. Not sure about the difference in L/R diff bushings. I've got STI engine/trans, WL subframe, and diff bushings. Removed the lower outrigger bushings. Very happy with this setup. Felt the WL trans insert bushing had a bit too much NVH for me.
bhmax is offline   Reply With Quote
The Following User Says Thank You to bhmax For This Useful Post:
smg1138 (07-15-2017)
Old 07-15-2017, 11:49 PM   #3
smg1138
smg1138's Avatar
Drives: 2013 Raven FR-S
I have the following Whiteline bushings and/or inserts: Steering Rack, Transmission Mount, Subframe, Differential, Sway Bars. I ended up removing the top and bottom outrigger inserts on the differential due to a clunking sound when shifting. After I removed those the clunk went away and it feels perfect to me.
smg1138 is offline   Reply With Quote
Whiteline differential insert bushings review Mikepage Engine, Exhaust, Transmission 149 11-04-2020 11:12 PM
Cusco Rear Differential Cooler Kit NoGoodNames Engine, Exhaust, Transmission 0 12-19-2016 11:13 PM
WTB: Stock LSD Rear Differential bshown Want-To-Buy Requests 0 01-24-2016 06:41 PM
Rear Differential Oil Change - How Often? Euro7R Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 50 06-15-2015 11:08 PM
Eww rear differential goo LeeMaster Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 13 04-10-2013 10:17 PM
