Old 06-09-2014, 03:37 AM   #1
Harvey
Drives: Celica 5th Gen, Tiburon 04, GT86
TSB Vin Number
Looking at this: http://www.ft86club.com/forums/attac...1&d=1352827748
This passage:
COUNTERMEASURE IN PRODUCTION
A countermeasure was incorporated into production in July, 2012 starting with VIN number
D*602788.
This shows a serial of 602788... there're aren't 602788 BRZ/FRS/GT86 out there? Mine has something like JF1ZN6L81DG007900 or something... am I concerned about this SERVICE BULLETIN?
Harvey is offline   Reply With Quote
Old 06-09-2014, 05:05 AM   #2
Harvey
Of course I'm asking because I have a sound....
Old 06-09-2014, 01:11 PM   #3
strat61caster
strat61caster's Avatar
Drives: '13 FRS - STX
Considering that's a Subaru bulletin for American market I'm not sure how useful it is to you.
But I'll assume it is.
What that statement means is that vehicles produced AFTER that VIN should not be affected. In other words, vehicles with a higher number are 'safe', vehicles with a lower number are potentially in need of the service.
Serial numbers generally do not follow production numbers identically in this day and age, there can be many different meanings behind them, maybe 100 were screwed up and scrapped, maybe there was a production change and they skipped 1,000 to denote the difference, maybe those starting with 3,xxx,xxx are for a specific market.
Edit: I'm bad at math, MVJ is right, if you assume the VIN numbers are the same region to region your number is AFTER the change was introduced. However if you are having the issue a good dealer will try to fix it anyway, notifying corporate that the problem still exists.
ineedyourdiddly
Old 06-09-2014, 01:36 PM   #4
MVJ1975
Automatic Hooligan
MVJ1975's Avatar
Actually, they're fairly close, but he's not reading that VIN correctly. The 6 is just a preceding digit that indicates it's a BRZ; the 02788 is the actual identifier for the car.
This TSB only concerns the first 2787 North American BRZs. European VINs are different.
MVJ1975 is offline   Reply With Quote
The Following User Says Thank You to MVJ1975 For This Useful Post:
strat61caster (06-09-2014)
Old 06-09-2014, 04:07 PM   #5
phobos512
phobos512's Avatar
Drives: 2014 FR-S 6MT Whiteout
VINs aren't always sequential. That's the short answer.
Matt | '14 FR-S 6MT Whiteout | '13 Sonata Hybrid | '11 CBR1000RR
phobos512 is offline   Reply With Quote
Old 06-09-2014, 09:00 PM   #6
MVJ1975
Automatic Hooligan
MVJ1975's Avatar
VINs aside, he can easily rule whether the TSB would apply to him or not by looking at the plate on his door jamb. If his car was made after July 2012, his car already incorporates the fixes, if not, he's possibly covered by this. Build date is on that plate (as an example, mine is March 2012, so the Toyota version of this TSB - if it existed - would apply to my car).
Old 06-10-2014, 05:03 PM   #7
Harvey
Hi, can you elaborate a little on this? Where exactly should I look to find the build date? Thank you
Old 06-10-2014, 05:28 PM   #8
strat61caster
Open your driver door. Towards the back of the car where the door covers you should see at least one sticker.
The stickers have a lot of information like recommended tire pressures, build date, VIN, where it was built, etc.
ineedyourdiddly
Old 06-11-2014, 09:48 AM   #9
Harvey
Hum... ok, I had in fact looked in the right place, it's just that my sticker (French GT86) is somewhat different that yours... bad thing is that "mfd in" doesn't appear, good thing is that some other interisting stuff does :
The Following User Says Thank You to Harvey For This Useful Post:
strat61caster (06-11-2014)
What number do you have? fayth22 Scion FR-S / Toyota 86 GT86 General Forum 88 04-24-2017 01:28 PM
Chassis Number Sco2355 ASIA 6 06-30-2013 01:13 AM
My FRS has two VIN number!! Bmore_Raven86 Issues | Warranty | Recalls / TSB 14 11-07-2012 12:12 AM
Vin number Solbadfrs Southeast 1 10-31-2012 12:32 AM
What's up with the number 127.0? avusblue Scion FR-S / Toyota 86 GT86 General Forum 13 06-22-2012 09:02 AM
