| Software Tuning Discuss all software tuning topics. |
Drives: FRS, Supra, Colorado D, GLC63
Finally got my OFT mounted
Ive been contemplating ways to mount my Tablet FOREVER, and finally had a weird dream about how to mount it last night
![]() I use a Rockform case for my iPhone 5s. It has a badass mounting system on the back and even a magnet. It is an impressive case. I few months ago, I accidentally dropped it in a large spill pan full of 5w-30. I pulled it out quick enough and the phone was fine, but the felt backing on the inside of the case turned into mush. So I bought another case and have had this other one lying around. This pictures show the rest. I cut the case with an air cutting wheel(not the best choice as it melts the plastic) and then use some 3M Double sided tape to adhere it to the back of the OFT. I then ran the cable under the steering column and into the ob2 port. It doesn't interfere with the turn signal and I use the same mounting spot with my phone turned sideways for gps and its perfectly visible in the drivers seat. Heres a link for the case: http://www.rokform.com/iphone5-cases/ I realize $40 is a little steep for a mounting solution, but if you sign up for their email list, I regularly get 20% off coupons and occasionally 40% ![]() ![]() ![]()
| The Following 13 Users Say Thank You to The Racers Line For This Useful Post: | Anorexic 86 (05-21-2014), FrsDuke (05-19-2014), Garrett@Openflash (05-21-2014), jbravo373 (05-19-2014), JonAvalon (05-18-2014), keen as (05-18-2014), neutron256 (05-18-2014), Pistol (05-18-2014), PMok (05-18-2014), Robert@Openflash (05-20-2014), Shiv@Openflash (05-18-2014), troek (05-18-2014), Tromatic (05-18-2014) |
#2 |
Now that, actually looks like a nice install! How easily does that clip in and out? Just a slight twist?
.o0+Eric+0o.
2016 Chrysler 200S 3.6 2013 FRS 6MT |
#3 |
Drives: 2013 FRS
That's really nice! I gotta try that myself. How sturdy is it? Does it vibrate/shake when you drive?
#4 |
#5 |
#7 |
Codename: Stitch
great job, looks good!
| The Following User Says Thank You to PMok For This Useful Post: | The Racers Line (05-19-2014) |
#8 |
The cut-and-paste method looks like it will for for a GTab as well!
#9 |
#10 |
Trim the Fat & add Boost
Drives: sometimes I fly
Clever,
![]() lol... that poor weathertech badge. |
#11 |
Drives: TIE interceptor; BRZ13
Great idea and good location. Any particular reason why u cut a case? instead using the universal mount $24.
"Speed has never killed anyone. Suddenly becoming stationary, that's what gets you." Jeremy Clarkson
| The Following 3 Users Say Thank You to TIE Pilot For This Useful Post: |
#12 |
#13 | |
Never on Time Always Late
Drives: #silenced crickets
Got some parts piling up..
CO>CA Cartel
| The Following User Says Thank You to Norkoastal For This Useful Post: | The Racers Line (05-20-2014) |
#14 |
For those not wanting to permanently glue anything to the back of the OFT, there is suction cup tape! I tested this morning and the OFT didn't budge an inch. This stuff is strong enough to stick to the dash piece and stay there.. Info below.. I'd probably recommend pulling it off and placing in the glovebox while parked in sunny spots as the OFT will bake.
"A 4 in x 1 in piece of the tape is strong enough to hold a 1 lb flat piece of steel to most non-porous, smooth, dry substrates." https://www.inventables.com/technolo...ction-cup-tape
CO>CA Cartel
| Anyone with pics of Enkei SR6 mounted? | ericmpena | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 3 | 08-07-2017 12:22 PM |
| fS SoCal swift springs already mounted | SliverBrz | Brakes, Suspension, Chassis | 4 | 10-14-2013 07:20 AM |
| Something new for us, mounted up a set of 19" wheels on the FRS - NOT BAD! | WheelDude.com | FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum | 44 | 10-01-2013 11:42 AM |
| where can i get my front spoiler mounted? | VoiD | Mid-Atlantic | 1 | 09-19-2013 12:08 AM |
| Stock Tires mounted? | feldy | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 4 | 06-19-2012 05:02 PM |
