Old 05-07-2014, 08:35 PM   #1
Cross
It's the Mad Cow
Cross's Avatar
Your choice in injectors for staying with the stock block
So I am not looking to build the motor any time soon but I am at the point in my build where it is time for fuel upgrades. (I still want to get a dyno before we do to see how far we were able to push the stock fuel system on FI and E85)
I am looking at the Deaschwerks fuel pump but I keep finding different opinions on fuel injector needs for my goal. I will not be going over 500 obviously giving the stock motor but I would like to think 380 to maybe low 400's would be possible as a high boost setting.
What are you guy's finding is working well so far? Any one using injectors off another Subaru or other vehicle that is easier to come across?
Thanks, I am searching and will update if I find what I am looking for but I would like some feedback from current users as well.
Old 05-07-2014, 08:39 PM   #2
Sportsguy83
I Love custom Turbo kits
Sportsguy83's Avatar
Drives: Limited BRZ
ID 1000's great to tune.....
The Following User Says Thank You to Sportsguy83 For This Useful Post:
Cross (05-07-2014)
Old 05-07-2014, 08:47 PM   #3
Cross
It's the Mad Cow
Cross's Avatar
I will look into those now, how about the Deatschwerks 700cc's? They also have smaller but the price is the same so unless they cause drive-ability issues I figured going bigger was probably better.
Old 05-07-2014, 08:53 PM   #4
Sportsguy83
Drives: Limited BRZ
DW's reputation is less than stellar.... I had FIC's, @jamesm has DW900's. From them all, he absolutely loves ID 1000's and I can atest to them as I tuned the drivability portion of them on my car with his help.
Cross (05-07-2014)
Old 05-07-2014, 08:58 PM   #5
Cross
It's the Mad Cow
Cross's Avatar
I guess it's go big or go home lol.
Thanks for letting me know DW is having reported issues I will go look for that now are they just failing? I ask because the fuel pump seemed like a great option.
Old 05-07-2014, 09:24 PM   #6
Sportsguy83
Drives: Limited BRZ
Nothing in particular about failures in BRZ... Just the general reputation you will find across the web about them, and know reputable vendors in here have posted before they dislike them because of failure rates.
Best pump to get is @fulblown Walbro 485 drop in tank kit.
Old 05-07-2014, 09:50 PM   #7
jamesm
I've had nothing but bad luck with DWs. I'm about to throw mine away and get some IDs.
Old 05-07-2014, 10:06 PM   #8
Reaper
in orbe terrum non visi
Reaper's Avatar
Drives: violent
I have 550s and a 270lph pump from fullblown if you want an inexpensive upgrade. I'm moving up to walbro485 and 1000s myself. Pm me if you're interested.
Sent from my SAMSUNG-SGH-I747 using Tapatalk
The Following 2 Users Say Thank You to Reaper For This Useful Post:
Cross (05-07-2014), Sportsguy83 (05-07-2014)
Old 05-07-2014, 10:57 PM   #9
Cross
It's the Mad Cow
Cross's Avatar
Message coming I am interested!
Old 05-08-2014, 11:18 AM   #10
King Tut
NASA SpecE30 Racer
King Tut's Avatar
Drives: 2006 Honda S2000
ID 100's great to tune.....
He might have trouble with some 100cc injectors.
The Following 2 Users Say Thank You to King Tut For This Useful Post:
ftc~brz (05-08-2014), Sportsguy83 (05-08-2014)
Old 05-08-2014, 11:20 AM   #11
Sportsguy83
Drives: Limited BRZ
LOL, would be limited to only vacuum, under 0 PSI....
One Thousand Cubic Centimeter per Mnute Injectors I meant.
Old 05-08-2014, 11:36 AM   #12
MAPerformance
Drives: Asphalt FRS
Pretty much agreeing with everyone on here. ID's or FIC's for sure. I have FIC 1100's on mine, and the car runs great! Part throttle, idle and start up is almost like stock. Didn't even have issues starting in the -27 degree winter we had this year.
MAPerformance is offline   Reply With Quote
The Following 3 Users Say Thank You to MAPerformance For This Useful Post:
ftc~brz (05-08-2014), jamesm (05-08-2014), Sportsguy83 (05-08-2014)
Old 05-08-2014, 01:53 PM   #13
HRTROB
HRTROB's Avatar
Drives: Toyota 86
What kind of issues are you having with the DW injectors?
I'm running the 700cc DW and I'm experiencing an idle dip when quickly jabbing the throttle at idle. I already had the car retuned several times by my tuner but they still could not tune it out. I was thinking that maybe it's the injectors. Initially I would get the idle dip even with slight tip in of the throttle but my tuner was able to fix that.
Startup is also not that smooth. When starting it would feel like the engine is dying then it would idle normally. Sometimes I have to crank it up a second time before it starts.
All this happened when I swapped the injectors. What do you guys think?
I know two other people who are having the same problem. Hard starting and idle dipping. We all have the same DW injectors and same tuner.
I got to try a Full Blown turbocharged car with Full Blown injectors tuned by the same tuner. It was very smooth. No idle dipping and startup was smooth.
HRTROB is offline   Reply With Quote
Old 05-08-2014, 02:00 PM   #14
Cross
It's the Mad Cow
Cross's Avatar
Alright I setup to buy the Full Blown Injectors and Pump from @Reaper. So problem solved, a member hooking up another can't beat that!
The Following User Says Thank You to Cross For This Useful Post:
Anyone try ID2000 injectors on stock ECU? Revolutions Performance Software Tuning 14 03-26-2014 01:10 PM
300+ WHP Innovate Supercharger, Stock Injectors, E85 and EcuTeK DeliciousTuning Forced Induction 75 03-11-2014 01:24 PM
Vortech Supercharged 270whp 86 AT stock injectors and pump Tye300 Forced Induction 3 12-16-2013 06:52 PM
Wanted: Looking for stock fuel injectors fst86frs Want-To-Buy Requests 1 09-16-2013 03:25 PM
