Old 04-01-2014, 08:48 AM   #1
kmbkk
First 86 Driver Baby!
kmbkk's Avatar
Drives: FR-S, Flex
Question P087 Code and Car Dies, EcuTek Tuned, FI---Help!
Guys,
I've had this problem for almost a while and it's really starting to bug me. It happens occasionally, not all the time, either after I've been driving for a while and get into stop and go traffic or after I've been driving for a while and make a couple of quick stops. The car will stumble, die, then I'll get the P087 (low fuel rail pressure) code. If I clear it and start moving again, it'll be ok for a few minutes, but if I stop again it reoccurs. If I clear it and wait a minute the car will do the same thing and I have to let it cool down some.
If anybody has any insight, or has experience wih this problem I'd really appreciate your assistance!
Kelly
kmbkk is offline   Reply With Quote
Old 04-01-2014, 08:54 AM   #2
s2d4
s2d4's Avatar
what does your log say?
The Following User Says Thank You to s2d4 For This Useful Post:
kmbkk (04-01-2014)
Old 04-01-2014, 09:02 AM   #3
xjohnx
Grip>Slip
xjohnx's Avatar
Originally Posted by kmbkk View Post
Guys,
I've had this problem for almost a year and it's really starting to frustrate me. It happens occasionally, not all the time, either after I've been driving for a while and get into stop and go traffic or after I've been driving for a while and make a couple of quick stops. The car will stumble, die, then I'll get the P087 (low fuel rail pressure) code. If I clear it and start moving again, it'll be ok for a few minutes, but if I stop again it reoccurs. If I clear it and wait a minute the car will do the same thing and I have to let it cool down some.
Kelly
I'd check your fuel pump install.
kmbkk (04-01-2014)
Old 04-01-2014, 09:29 AM   #4
stugray
Drives: 2013 GBS BRZ Limited
Based on some of the comments in the "Blown BRZ motor" thread, low fuel pressure can be very bad.
I would get that fixed before some "non-linear catastrophic structural exasperation" occurs. (aka - BOOM)
The Following User Says Thank You to stugray For This Useful Post:
kmbkk (04-01-2014)
Old 04-01-2014, 09:32 AM   #5
Sportsguy83
I Love custom Turbo kits
Sportsguy83's Avatar
Drives: Limited BRZ
Guys,
Kelly
did you get with James for new tune or still using the old tune? I would look at in tank fuel pump install.
If he is still in his old tune, its the same tuner...
The Following User Says Thank You to Sportsguy83 For This Useful Post:
kmbkk (04-01-2014)
Old 04-01-2014, 10:33 AM   #6
wparsons
wparsons's Avatar
Is it possibly an overheating (or faulty) pump? If letting the car (and pump) cool fixes it temporarily it would make sense that the pump is struggling when it gets warm.
flickr
kmbkk (04-01-2014)
Old 04-01-2014, 11:16 AM   #7
kmbkk
kmbkk's Avatar
Drives: FR-S, Flex
Thanks for the quick responses guys! To answer your questions:
-I haven't been able to log it as it's intermittent, and usually occurs when I'm driving home from work.
-I'm on a base tune by @jamesm.
A little more info on my car:
-265 LPH Treadstone fuel pump.
-stock injectors
-running ~10-12 psi boost, but definitely baby the car.
The Following User Says Thank You to kmbkk For This Useful Post:
Sportsguy83 (04-01-2014)
Old 04-01-2014, 11:18 AM   #8
Sportsguy83
Drives: Limited BRZ
-I'm not on the old tune, thankfully. I'm using a base tune by @jamesm. I'm already in communication with him about this.
-stock injectors
-running ~10-12 psi boost, but definitely babying the car until we dial in the tune.
I would first and foremost look at in tank fuel pump install.
The Following 2 Users Say Thank You to Sportsguy83 For This Useful Post:
kmbkk (04-01-2014), wparsons (04-01-2014)
Old 04-01-2014, 11:21 AM   #9
xjohnx
Grip>Slip
xjohnx's Avatar
Agreed. It should be apparent in the logs, even if it's not actively presenting itself in a perceivable manner. When my fuel pump was initially installed incorrectly, @DeliciousTuning was able to see the fuel rail pressure falling off at higher RPM's (even though the car wasn't acting funny at that particular moment).
The Following 2 Users Say Thank You to xjohnx For This Useful Post:
kmbkk (04-01-2014), Sportsguy83 (04-01-2014)
Old 04-01-2014, 11:26 AM   #10
kmbkk
kmbkk's Avatar
Drives: FR-S, Flex
Got it, thanks!
Old 04-01-2014, 11:30 AM   #11
xjohnx
Grip>Slip
xjohnx's Avatar
Got it, thanks!
I found the log from when I was having a similar issue. I don't have ProECU handy on this PC, but i tossed it into excel so you could see the rail fuel pressure vs RPM from my issue and compare with your logs to see if you notice anything similar.
Old 04-01-2014, 11:33 AM   #12
jamesm
We haven't done any wot logs yet, just a basemap to get the car running safe.
The Following User Says Thank You to jamesm For This Useful Post:
Old 04-01-2014, 03:01 PM   #13
kmbkk
kmbkk's Avatar
Drives: FR-S, Flex
Here's a log from a few weeks ago:
Old 04-01-2014, 03:10 PM   #14
xjohnx
Grip>Slip
xjohnx's Avatar
Bingo. I'd bet money it's the fuel pump. Easy enough to fix. If you need extra o-rings, NAPA sells them, part # 2-12093 for 2 of them.
P0068 code on tuned vortech help please Frs32907 Forced Induction 23 04-09-2014 08:19 PM
Circuit Motorsports - EcuTek Tuned Stock BRZ: 191whp / 163wtq: +17whp & +12wtq!! Circuit Motorsports Engine, Exhaust, Bolt-Ons 16 09-24-2013 11:17 AM
EcuTek ProECU Moto-East Tuned Group Buy! Xero-Limit Groupbuys 52 04-19-2013 12:58 PM
P0172 Code with Injen Intake, will EcuTek tune help? ron_jeremy Engine, Exhaust, Transmission 0 11-27-2012 11:22 AM
Invidia TI exhaust Dynoed and Ecutek tuned(Video) Ny Brz Engine, Exhaust, Transmission 12 10-12-2012 11:13 AM
