Drives: FT86
Which EBC?
Hi guys,
I currently have the AEM failsafe - was wondering which EBC you guys use? I really want utilise the failsafe function and was wondering if there are any models that fit below the aircon/heating controls, in that little tray area. Cheers! |
#2 |
Drives: Sterling BRZ Ltd
Maybe try turbo smart eboost street, it's small and rectangular.
| The Following User Says Thank You to mrk1 For This Useful Post: | mswhong (03-20-2014) |
#3 |
Drives: FT86
#4 |
Boosted Member
Drives: 2013 Subaru BRZ
I use a COBB 3 port so my boost is electronically controlled via the ECU (and therefor switchable via maps on the fly thru EcuTek).
2013 Subaru BRZ LTD 6MT DGM
2014 Subaru XV Crosstrek Hybrid TRG PG 2011 Honda CBR1000RR 2010 Subaru Impreza WRX PRM SSM |
| The Following User Says Thank You to woode For This Useful Post: | mswhong (03-20-2014) |
#5 | |
Drives: FT86
Will be using a haltech unit as I live in Australia - that said, i would still like an EBC.. will most likely be using the eboost1 at this point |
#6 |
Drives: White 2013 FRS
Same as Grimm Speed: http://circuitse7en.net/fantcube/ind...d&productId=13
#7 |
Drives: FT86
^I was after an EBC not a manual one, which I presume that one is
#8 | |
NASA SpecE30 Racer
- King Tut
Street/Track Car: 2006 Honda S2000 TT3 || Race Car: 1987 BMW 325is SpecE30 || Tow Vehicle: 2014 RAM 1500 EcoDiesel Sold Cars: 2012 BMW M3 || 2013 Subaru BRZ || 2012 Porsche Cayman R || 2009 Chevrolet Z06 || 2009 BMW M3 || 2004 BMW M3 || 2004 Nissan 350Z |
| The Following User Says Thank You to King Tut For This Useful Post: | mswhong (03-20-2014) |
#9 |
Drives: FT86
#10 |
Drives: 2013 FRS Whiteout
I tried both Turbosmart and AVO EBCs, they both work well if you know how to set them up right, but its not as simple as 10 PSI = 10 PSI, you have to set wastegate duty cycle and gain settings to achieve the proper boost at the proper rate.
#11 |
Is this all that difficult? Arn't those adjustments the advantages of a EBC over a manual.
#12 | |
You can also easily wire the AEM fail safe gauge to provide boost-cut to the solenoid so your boost drops to wastegate spring pressure if the AEM gauge detects anything off. |
| The Following User Says Thank You to OjiGeorge For This Useful Post: | mswhong (03-21-2014) |
#13 |
Just noticed that you won't be using EcuTek.. not sure about the Halteck's abilities for controlling a boost solenoid.. but for the price I'd assume it can? If EBC's are illegal in Aus, this is also a much more stealth way to have ebc without an external controller.
#14 | ||
Drives: FT86
I would also assume that the haltech unit can be wired up to solenoid you linked me to - I mean, you would expect it to when I am paying something close to $1200 for the Platinum Sport 1000. |
