Old 02-03-2016, 03:11 PM   #1
lupindub
Drives: Scion FR-S
What do you guy's do with the unused oil?
Since our car requires aprox. 5.5 quarts of oil, we need to buy 6 quarts of oil per oil change. So what do you guy's do with the unused and open .5 quart of oil? I heard oil can go "rancid", especially after the factory packaging has been opened. Is this an old wives tale or truth behind this, and does this only apply to standard oil or to synthetic as well?
lupindub is offline   Reply With Quote
Old 02-03-2016, 03:13 PM   #2
go_a_way1
Not Bаnned Anymore
go_a_way1's Avatar
Drives: Heavily Modified FRS
Originally Posted by lupindub View Post
Since out car requires aprox. 5.5 quarts of oil, we need to buy 6 quarts of oil per oil change. So what do you guy's do with the unused and open .5 quart of oil? I heard oil can go "rancid", especially after the factory packaging has been opened. Is this an old wives tale or truth behind this, and does this only apply to standard oil or to synthetic as well?
Installed an oil cooler so it takes all 6L hahahha! I have a ton of half bottles in my room. no idea why I keep them. Yeah it can go "bad" with enough time, applies to all oil
Dream20b (02-13-2016)
Old 02-03-2016, 03:29 PM   #3
Jesse36m3
Jesse36m3's Avatar
Drives: JDL Turbo BRZ
Keep it in the trunk next to the spare tire so I can top off if needed when I'm out.
Jesse36m3 is offline   Reply With Quote
The Following User Says Thank You to Jesse36m3 For This Useful Post:
fumanchu1 (02-03-2016)
Old 02-03-2016, 03:40 PM   #4
Pat
Pat's Avatar
Drives: 2023 BRZ
Keep it for the next oil change. It'll be just fine for a few months in the original packaging.
Old 02-03-2016, 03:45 PM   #5
lupindub
Drives: Scion FR-S
Few months might be okay.. but I don't drive the car much so I only change to oil every 7.5 month. Nearly 3/4 of a year and the oil will still be fine?
Old 02-03-2016, 03:53 PM   #6
ryoma
ryoma's Avatar
I drain my oil until it starts dripping, close it off, then pour in the extra half quart and let it accumulate for like 5-10 minutes, then open the drain plug again and let it flow out. probably a waste of .5 qt but it makes me feel better to have clean oil rinse through lol
The Following User Says Thank You to ryoma For This Useful Post:
NyC Zn6 (02-12-2016)
Old 02-03-2016, 03:56 PM   #7
RRnold
2 wheel member
RRnold's Avatar
Drives: JZA80, 997.1, Taco
It depends on your conditions but oil has a good shelf life.
http://www.mobilindustrial.com/ind/e...mendations.pdf
Old 02-03-2016, 04:10 PM   #8
go_a_way1
Not Bаnned Anymore
go_a_way1's Avatar
Does it really rinse much or just flow right down into the oil pan?
Old 02-03-2016, 04:10 PM   #9
Pat
Pat's Avatar
Drives: 2023 BRZ
It'll be fine. Don't sweat it.
Old 02-03-2016, 04:36 PM   #10
ryoma
ryoma's Avatar
it probably just flows right into the oil pan, but I would like to think it would grab some old oil on its way down lol
The Following 2 Users Say Thank You to ryoma For This Useful Post:
go_a_way1 (02-03-2016), JoeeStacks (02-03-2016)
Old 02-03-2016, 05:22 PM   #11
fumanchu1
Drives: 2013 Brz C38 (bought not built :P)
Wishful thinking maybe?
eh why not, I mean it was just gonna be wasted oil anyways
fumanchu1 is offline   Reply With Quote
Old 02-03-2016, 07:34 PM   #12
stevesnj
stevesnj's Avatar
You may burn some so keep it for topping off.
My 2016 Build thread
Old 02-03-2016, 09:22 PM   #13
Mr.ac
[insert cool phrase here]
Mr.ac's Avatar
Drives: BRZ Premium
You make me faceplam, and question your generation.
Joking aside,
As long as don't store it in an open container, oil will go "rancid" in about 10 years and that if you have oil from the 80's. Today's oil would be good for up to 20 years.
So yeah it's an old myth
Like others said, either keep it in the garage or keep it in the trunk.
Old 02-04-2016, 04:09 AM   #14
Decay107
Turning is for Nerds
Decay107's Avatar
Drives: 35 characters is not enough
I drink it mixed with methanol and mountain dew
Decay107 is offline   Reply With Quote
The Following 2 Users Say Thank You to Decay107 For This Useful Post:
Dream20b (02-13-2016), RobertPaulson (02-04-2016)
Unused Parts Give Away Dezoris Scion FR-S / Toyota 86 GT86 General Forum 31 04-10-2015 02:38 PM
FS: NEW UNUSED Bridgestone Potenza RE-11s set of 4. BRZZZZZZZZZZ Canada Classifieds 3 05-14-2014 08:47 AM
For Sale: SPC LCA ***NEW*** unused dkx64 Southern California 0 03-21-2014 12:05 PM
SOLD - 3 BAR Map sensor NEW, unused Amadeus Engine, Exhaust, Bolt-Ons 2 08-19-2013 12:25 PM
Storing an unused car? #87 Off-Topic Lounge [WARNING: NO POLITICS] 10 02-21-2012 10:51 PM
