Old 12-17-2013, 11:48 PM   #1
Deadspool
Much title. Wow.
Deadspool's Avatar
Drives: 2013 BRZ Sport-Tech
ECUTek detecting car
Has anyone else ran across this issue?
Fresh install of windows 8, uninstalled and reinstalled everything at least 6 times now, drivers, proecu and apploader. Now stumped.
https://www.dropbox.com/sc/z8z3149j1faxfr9/Q0uOdK4S_J
Deadspool is offline   Reply With Quote
Old 12-17-2013, 11:50 PM   #2
Deadspool
Much title. Wow.
Deadspool's Avatar
green light on the cable too
Old 12-18-2013, 12:53 AM   #3
Apoc
Apoc's Avatar
Drives: Raven FR-S 6M
Green light only means it recognizes the Ecutek cable. I get the green without being plugged in to the car. Check your OBD2 connector.
“The World is Flat”
[||•]=(86)=[•||]
Apoc is offline   Reply With Quote
The Following User Says Thank You to Apoc For This Useful Post:
Deadspool (12-18-2013)
Old 12-18-2013, 12:55 AM   #4
pixel67
pixel67's Avatar
Drives: 13 Asphalt FRS AT
Try taking the cable and wrapping it around the steering column once so that it puts lateral pressure on the connector. The factory female connector can get worn after plugging in several times.
Sent from my Nexus 7 using Tapatalk
pixel67 is offline   Reply With Quote
The Following User Says Thank You to pixel67 For This Useful Post:
Old 12-18-2013, 01:00 AM   #5
Deadspool
Much title. Wow.
Deadspool's Avatar
I tried something similar, but with a lot more yoga involved.
Ill take the connector down in the morning and check the pinning..
The other issue is not being able to load a rom file. I certainly have no idea what it is asking for. "Unable to Identify Rom Array Class."
Old 12-18-2013, 02:37 AM   #6
SmsAlSuwaidi
Boosted
SmsAlSuwaidi's Avatar
Drives: Not a supra....yet
Check this out, it might be helpful
[ame]http://youtu.be/se5LVsiTfvo?t=16m21s[/ame]
The Following User Says Thank You to SmsAlSuwaidi For This Useful Post:
Old 12-18-2013, 07:16 AM   #7
EcuTek
Drives: Toyota GT86
Hi,
Please use EcuTek Update again which will build you a new version of ProECU.
I'm very sorry but we had small issue with our build system which is now fixed.
EcuTek Team
EcuTek is offline   Reply With Quote
The Following 3 Users Say Thank You to EcuTek For This Useful Post:
Deadspool (12-18-2013), gdrider77 (12-18-2013), Ryan P (12-18-2013)
Old 12-18-2013, 07:23 AM   #8
ecko04
Seems Legit
ecko04's Avatar
Drives: Toyota
Open your ROM file using notepad. If there's nothing there you have a corrupted ROM file. I contacted EcuTek about it. That happened to me a few times with the exact same error. The file size is correct but it's full of nothing.
Now, if you open the file and it's full of hieroglyphics then you have a good file that should load.
No build thread. I don't want to be reminded of how much money I spent.
[insert profound quote here]
ecko04 is offline   Reply With Quote
The Following User Says Thank You to ecko04 For This Useful Post:
Old 12-18-2013, 01:02 PM   #9
Deadspool
Much title. Wow.
Deadspool's Avatar
Its full of Egypt!
I will remember this trick in the future, Definitely a good tip to point at either the installation or the rom file itself.
Old 12-18-2013, 01:05 PM   #10
Deadspool
Much title. Wow.
Deadspool's Avatar
Originally Posted by EcuTek View Post
Hi,
EcuTek Team
Perfect, works like a charm now when opening the tune file. I will test it in car inbetween snow storms at some point today.
Thanks!
Old 12-18-2013, 01:25 PM   #11
Deadspool
Much title. Wow.
Deadspool's Avatar
This guys videos are very entertaining to watch lol
Ecutek's 86 jpit FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 10 07-12-2013 01:35 PM
I need help on which ecutek I should get, stg 1 or 2 Frsexxxy Engine, Exhaust, Transmission 22 03-29-2013 11:45 PM
Which should I get ecutek stg 1 or stg 2? Frsexxxy Engine, Exhaust, Transmission 5 03-21-2013 02:10 PM
As all our cars are pretty much brand new!! Motion Detecting Dash Cams!! eddieEndo Scion FR-S / Toyota 86 GT86 General Forum 22 02-28-2013 04:42 PM
ECUTEK????? 20valvewynn83 Engine, Exhaust, Transmission 4 10-03-2012 10:34 PM
