| Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack Specific topics relating to wheels and tires. |
Shriveled Old Member
Drives: 14 Hot Lava FR-S
RATIONAL Wheel & Tire Selection?
Still considering getting an FR-S, the first (and probably only) thing I'd likely change would be the wheels. Am a big fan of RPF-1s (made a huge difference on my Miata) or any wheel that's lighter than the stock setup.
Since this car is going to be my daily driver (with an occasional autocross session), I'm wondering just how much wheel I really need. I don't plan to lower the car, I don't want to go any larger than 17s, and from what I've been reading the car doesn't really need rubber that's wider than 8 inches. So... questions: How much rubber do I really need? Would a 17 X 7 setup with reasonably sticky tires (Falken Azenis, Nitto NT-05) give me sufficient cornering traction without the penalty of the added rolling resistance of 17 X 8s? I see that you can't even get RPF-1s in anything narrower than a 17 X 8. What other wheels are available in a 17 X 7 or 17 X 7.5 that would be lighter than the stock wheels? Wheel weight is my primary concern. Thanks! |
#2 |
Off Topic
You can put 225/45-17s on a 7" wheel. You could honestly stick with 215/45-17s and just upgrade the tire. You don't even need NT05s or Azenis, most people will suggest Michelin Pilot Super Sport 3s or Continental DWs. Either would be a huge upgrade, even in the stock size.
#3 |
So... is there a list somewhere of 17 X 7s that are lighter than the stock wheels? I see all kinds of photos of nice looking wheels on this forum, but nobody ever seems to list the wheel's weight. And I almost don't care what a wheel looks like-- my preference is for getting rid of as much unsprung weight at possible, within reasonable limits of price and durability.
#4 |
Off Topic
I haven't seen one. The wheel fitment sticky is worried more about offset than weight. I would think that any of the Enkei racing series or the normal light wheel manufacturers (Advan, Rays, SSR, Wedsport, etc...) would be lighter than stock, but that's just a guess.
#5 |
Slower than Fast
Drives: BRZ Limited 6MT
The RPf1's do come in 17x7's as well as 17x7.5's:
http://www.tirerack.com/wheels/Wheel...All&sort=Brand And they're less than 15lbs each. Pretty impressive.
#6 |
Drives: 2013 Scion FR-S - Argento
My wheels are 17X8.5 and 4lb lighter than stock each.
Even going up to 245 Pilot AS3, I'm still at 2-3lb less per corner than stock. So I'm sure if you stuck with 7's or 8's you can go quite a lot lighter. (FYI - I'm on Forgestar F14) |
#7 |
Drives: Slowly
Then you want these:
http://www.ft86club.com/forums/showthread.php?t=32071 TWS T66-F 10.6lb wheels Sent from my Nexus 4 using Tapatalk |
#8 |
Off Topic
Or these. 5kg wheel, 10.5kg tire. About 34 lbs per corner instead of 42 or whatever OEM weighs.
http://www.ft86club.com/forums/showthread.php?t=62734 |
#9 |
16x7 TWS T66-F wheels = 4.82kg for ultimate weight savings.
17x7, 17x7.5, and 17x8 yield little differences in rolling resistance. You can even put a 215 on a 8" and be perfectly fine. The benefit is gaining additional sidewall stiffness from the proper "stretch". |
#10 |
AIM4APX
Drives: 2013 WRB BRZ Limited
Im running a 17x8 RPF1 with a 245/45 Dunlop ZII. It's WAY more stick than the original tire but that combo is also the same weight as the original wheel/tire combo. That said if you went with a 17x7 and skinnier tire you could come in under the OEM combo weight for sure.
"It's very difficult to present technology as an overtly positive sales device to people who want an emotional car" -Chris Harris
#11 |
Drives: '13 Nissan Frontier (4.0L 6spd 2WD)
Any wheel 20 lbs or less is lighter than the stock wheels...the stock wheels @ ~20.8lbs are not really a "light" wheel for this car. I'd stick to ~17lbs or less wheels, which you can search for by weight on Tire Rack...
Really though, you should decide on what tire size you want to run first, then determine needed wheel size based off that. Stock 215/45-17 size tires in a better compound works very well for the car, and on proper lightweight 17x8 wheels you'll shed ~ 5 lbs a corner... To me though, the 215/45-17 Kumho Ecsta XS I have are too much tire for daily driving and I either need to drop down a grade in compound (like to Max performance with some LE Sports) or decrease the tire tread width...or do both at the same time. Oh wow...Kumho now has $100 rebate offer on the LE Sports....think I'll try them out in 205/45-17 on my 17x7.5 set of wheels so I can compare them to 215/45-17 XS on 17x8 wheels...I've had the LE Sport before on a slightly heavier vehicle and it was an excellent rain tire and should have better dry stick than the stock tires (the 205/45-17 Ecsta LE tread is wider than the stock 215/45-17 Michelin Primacy HP tread...and should have a sticker rubber compound)
Had a '13 FR-S Asphalt 6spd manual (bought new 5/25/12, sold 6/10/20) but needed to let her go... she will be missed.
#12 |
Drives: '13 BRZ Ltd
As mentioned, the RPF-1 comes in 17x7 and is very light (I have them). For a DD tire there's nothing wrong with sticking with the 215/45 - they will be a little lighter and have less rolling resistance, and even though the 225 doesn't increase the OD all that much I swear I could notice the slower accel on the buttdyno.
#13 | ||
So I'm interested in moving to a car that's a little quieter and a tad more comfortable than the Miata, while still being fun to drive. Am thinking an FR-S, with some minor modifications, might fit the bill nicely. |
#14 | |
Car Nut
Drives: BMW 335d, Toyota Echo RS, FRS
| Help on tire selection for fronts!@! | charged86 | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 0 | 08-08-2013 09:10 AM |
| Need help with wheel selection | Spencer Strayer | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 1 | 03-12-2013 04:15 PM |
| help with tire selection? | bakerr6 | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 2 | 01-30-2013 10:49 AM |
| Help please for wheel selection | Skye | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 6 | 08-08-2012 08:40 PM |
| BRZ added to tirerack for tire selection... | mines13 | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 5 | 12-05-2011 11:19 PM |
