Old 01-28-2013, 05:09 PM   #1
bakerr6
Drives: 2013 raven black fr-s
help with tire selection?
Ok guys, so I am going to be runnning motegi traklite wheels for autox this year, and was wondering what tires I should run (not going FI until after this season, so I saw no reason to go with a wider wheel).
The wheels are 16x7 and +40 offset.
I was thinking I should probably run a 225/50/16 in hankook ventus v12 or continental extremecontact dw?
any other suggestions will be taken into consideration. Looking for something I can use in wet traction also
bakerr6 is offline   Reply With Quote
Old 01-29-2013, 08:40 PM   #2
enjoyminutemaid
enjoyminutemaid's Avatar
Drives: Subaru BRZ Limited WRB Manual
FWIW, I ran the hankook v12s in that same tire size, same exact wheel (different bolt pattern) on my 08 VW GTI and was NOT impressed. They are fine for road use and relatively comfortable, but they certainly didn't feel very sporty or responsive. They heated up quickly, even in autox, and became useless pretty quickly... Are these exclusively autox/track tires or will you be dd'ing them too?
EDIT: If these are autox/track tires, I think you might be happy with these (I think the smaller size will be better, plus give you more aggressive final drive ratio for better acceleration)- http://www.discounttiredirect.com/di...15&ar=45&rd=16
OR
these... http://www.tirerack.com/tires/tires....omCompare1=yes
enjoyminutemaid is offline   Reply With Quote
Old 01-30-2013, 09:49 AM   #3
bakerr6
thanks for the reply, these for now are dd wheels/tires for the summer. I have a set of dedicated winters, but we get a lot of rain around here, so something a little softer is needed. I went ahead and bought the continentals. I'll let you guys know how I like them in a couple months.
FR-S/BRZ Old Timers Club name selection einzlr Scion FR-S / Toyota 86 GT86 General Forum 9 11-06-2012 01:24 PM
Muffler selection... jm1681 Engine, Exhaust, Transmission 24 09-28-2012 08:16 PM
Help please for wheel selection Skye Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 6 08-08-2012 07:40 PM
Win a selection of parts for you FR-S AX_FRS Scion FR-S / Toyota 86 GT86 General Forum 13 07-17-2012 11:58 PM
BRZ added to tirerack for tire selection... mines13 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 5 12-05-2011 10:19 PM
