Old 08-25-2013, 12:05 PM   #1
jflogerzi
jflogerzi's Avatar
Rota Wheel Quality Questions
600-700$ for what looks to be a semi decent cast 1 piece wheels which if staying in the 17x8 range is a bit lighter than stock and should allow for slightly wider tires. 18x8's also look to be a great option with little price increases. I don't care for real wheels that cost an arm and a leg. I do not show off my car at shows etc... I want best bang for my buck because I drive my car. For people who have Rota Wheels on the FR-S/BRZ what was your thoughts on quality, looks, and driving impressions.
I have to say I love the look of the 17x8 Rota G-Force Hyper black! With some nice long blue color lugs would make an Argento car pop! Then get some 225/45 sized rubber(probably Michelins SSP's for traction, tread wear and a great tire.
Old 08-26-2013, 10:50 AM   #2
frslee
Just drive it
Drives: 13' FR-S
A lot of people have Rota wheels. As discussed before, track cars run these wheels too. Unless you don't do crazy stuff, these should be fine.
frslee is offline   Reply With Quote
Old 08-26-2013, 11:00 AM   #3
ZionsWrath
Thanks
ZionsWrath's Avatar
Pretty sure the are drift and track cars sponsored by and running rota. So Unless you are competing for 0.01 it is probably fine.
I think Rota best quality is you can buy a used set for CHEAP lol
Personally I'll most likely stick with Enkei, may buy some Titans though I like them a lot
Old 08-26-2013, 01:53 PM   #4
Cjymiller
Original 2013 Owner
Cjymiller's Avatar
Drives: 13 BRZ, Galaxy Blue Silica
Rota wheels are a great value. They conform to the same quality standards as OEM manufacturers. Little do people know, but Rota actually is the manufacturer for many OEM wheels.
Perrin Headerback, OFH, OFT, Ohlins R&T MI20, 17x9 Weds TC105N, Hankook RS4 (235/40), TOM's JDM Tails, PCV AOS, Perrin Crank Pulley, Perrin Rear Trans. Mount, Whiteline Shift Bushing, SS brake Lines, Hawk DTC60, Bayson R Lip Kit, LED Lighting , Smoked JDM Sidemarkers, Rear Fog Enable, Carsmo Armrest, Grimmspeed Plate Relocater
φφκα
Cjymiller is offline   Reply With Quote
Old 09-07-2013, 08:14 AM   #5
CaptivaBlueTeg
Drives: WRB Brz
Everyone says they break, this and that. I've seen te37's break. Doesn't matter how they are made, you nail a curb straight on you'll do damage to any rim.
My only complaint is, they have gotten more expensive in the past few years. I'm looking at the MXR's...but they're $1000 for the set. I paid that for my old axis wheels new mounted with tires. Also not much cheaper than my 5zigen f10rc were a piece either. In fact, actually saw a sale on those for less than the rotas
CaptivaBlueTeg is offline   Reply With Quote
Old 09-07-2013, 08:42 AM   #6
Pitman
Living the dream
Pitman's Avatar
Drives: Fensport AVO Turbo GT86
I have Rota Grids on my car (fitted approx 6 months ago) and am completely satisfied with them. Unfortunately, there are a lot of broscience experts on the internet who love to boost their egos by bad mouthing various products. Very often, this is based purely on speculation, and no real knowledge. A lot of OEM alloy rims are cast.
Pitman is offline   Reply With Quote
Old 09-07-2013, 10:39 AM   #7
fstlane
fstlane's Avatar
Drives: BRZ Limited
For my daily driver/autocross BRZ the Rota Titans offered the best combination of value, weight and appearance. Here is a good article on Rota wheels I came across while researching them.
http://custompinoyrides.com/2012/03/...f-rota-wheels/
fstlane is offline   Reply With Quote
The Following 3 Users Say Thank You to fstlane For This Useful Post:
IAmNotTheDriftKing (01-31-2014), Pitman (09-07-2013), ZionsWrath (09-07-2013)
Old 09-07-2013, 10:57 AM   #8
ZionsWrath
Thanks
ZionsWrath's Avatar
What wheel specs, looks perfect
Old 09-07-2013, 11:02 AM   #9
JesseE
JesseE's Avatar
Drives: LS Swapped BRZ
I don't mind rotas, I've had a few sets on various cars, never had a problem besides the center cap sticker falling off :-P I've tracked/drifted/DD'd on rotas, never had a failure, nor have I ever seen a failure in person.
Currently I have Rotas 18x9 on my frs, put 10k miles on them already, love em.
JesseE is offline   Reply With Quote
Old 09-07-2013, 11:28 AM   #10
fstlane
fstlane's Avatar
Drives: BRZ Limited
Thank you! They are 17x9 et42 Rota Titans in Sports Bronze.
Old 09-07-2013, 11:40 AM   #11
ZionsWrath
Thanks
ZionsWrath's Avatar
ugh I want that spec so bad but they won't fit stock with any amount of camber
Wish they made a 17x8.5 5x100
Old 09-07-2013, 11:50 AM   #12
fstlane
fstlane's Avatar
Drives: BRZ Limited
Unfortunately you are correct. I have around 4mm of strut clearance running 245/40R17 Direzza ZII's. Not much room for camber adjustment with crash bolts so I'm running HVT plates which allow me to run -2.0 degrees of camber.
Old 09-09-2013, 09:12 AM   #13
Turdinator
Señor Member
Turdinator's Avatar
[IMG]
I've been thinking the titans were a good thing for a while now. Have you posted more pics anywhere?
1974 TA22 Celica
2013 86 GT
Old 09-09-2013, 02:58 PM   #14
fstlane
fstlane's Avatar
Drives: BRZ Limited
Here's a closeup.
The Following 2 Users Say Thank You to fstlane For This Useful Post:
jflogerzi (09-10-2013), Turdinator (09-09-2013)
B2Designs Hub-Centric v1, v2 and v3 wheel spacer. Great quality. b2autodesigns Wheels and Tires 813 08-01-2017 11:34 AM
Noob wheel questions pornflakes AUSTRALIA 11 05-31-2013 02:43 AM
Rota D wheel thread Mach V Dan Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 0 03-05-2013 12:46 PM
Rota Wheel Fitment and Where to buy CharlieChaos Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 7 08-21-2012 05:30 PM
Rota mock up to test wheel fitment...... close enough Spaztastik Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 9 07-12-2012 02:47 AM
