Old 08-13-2013, 03:59 PM   #1
Scalzo
Scalzo's Avatar
Drives: Asphalt FRS <3
higher Boost?
So i want to boost higher than 7psi, Maybe 9psi, how could I do this?
I have the fa20club kit + external waste gate + blow off,
I was told all i have to do is switch the spring in the wategate to boost higher?
Scalzo is offline   Reply With Quote
Old 08-13-2013, 04:08 PM   #2
jamesm
prick answer: if you have to ask that, you should probably sell the turbo kit before you blow up your car and/or hurt yourself.
nice guy answer: you need a boost controller, and a retune.
Old 08-13-2013, 04:13 PM   #3
Ross
Drives: 85 corolla gts
Contact FA20Club. As you may need fueling upgrades ect. They will be able to get you straight and the parts required to do what you are looking to do. Have fun.
Ross is offline   Reply With Quote
Old 08-13-2013, 04:18 PM   #4
Scalzo
Scalzo's Avatar
I figured you needed a boost controller but when i had my genesis , i just played around with the actuator, and i was able to raise the boost up very little.. I don't know why someone would tell me to change the springs.....
i figured not sense.
Old 08-13-2013, 04:21 PM   #5
Sportsguy83
I Love custom Turbo kits
Sportsguy83's Avatar
Drives: Limited BRZ
Either a manual boost controller, electroinc boost controller, EBC Solenoid or bigger spring. Oh, also new tune to account for higher PSI.
Old 08-13-2013, 04:32 PM   #6
Scalzo
Scalzo's Avatar
Thanks,
Sent from my HTC One using Tapatalk 2
Old 08-13-2013, 04:37 PM   #7
crook
crook's Avatar
Drives: storm black GT
An external gate opens up when the desired pressure (boost) is reached to dump excess exhaust to stop the turbo making more boost, this pressure is altered by changing the springs inside the wastegate... The actuator your talking about from your genesis was obviosly on an internally gated turbo, is esentially the same thing.. I take it when you say fiddled with it you were adjusting the rod going from the actuator to the exhaust housing on the turbo.
Hope I've made that clear enough and worded right :s
crook is offline   Reply With Quote
Old 08-13-2013, 05:06 PM   #8
Scalzo
Scalzo's Avatar
Yeah that's exactly what I did. I'm still in the learning process I appreciate it guys.
So from what I understand I can get an electronic boost controller and then have Toni retune it.
Old 08-13-2013, 05:08 PM   #9
Scalzo
Scalzo's Avatar
And when I raise the boost I have to change the spring to the psi I raise it by right?
Old 08-13-2013, 05:10 PM   #10
jamesm
if you're just starting out i'd stick to an mbc. you'll get much better results much easier with a quality mbc than you will with an electronic setup. unless you plan you change boost while you drive a lot, they're the best option in terms of ease of use/tuning and reliability.
another option is to get the boost solenoid and just have tony tune it, but that's probably still more expensive/error-proned than a good mbc.
Old 08-13-2013, 05:25 PM   #11
lexusb3
Drives: FRS
I have electronic and I can change boost on the go with the cruise controls from ecuteck low boost mid and high settings
lexusb3 is offline   Reply With Quote
Old 08-13-2013, 05:36 PM   #12
Scalzo
Scalzo's Avatar
Any you recommend? Would I need it to be retuned of I'm just raising the boost 2psi
Old 08-13-2013, 06:03 PM   #13
Andy@FA20Club
Drives: FA20Club.com
Soon
Andy@FA20Club is offline   Reply With Quote
Old 08-13-2013, 06:12 PM   #14
Sportsguy83
Drives: Limited BRZ
Glad you have it working already
strong odor @ higher rpm's mRdeMs83 Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 91 05-31-2021 08:07 PM
Octane booster: 91 to 93 or higher? mike the snake Forced Induction 18 08-13-2013 08:54 PM
Where can i get fuel higher than 91? XPR Small Block Northern California 22 03-24-2013 09:56 AM
Does the higher side of the K&N drop in filter go Liquidsnake Engine, Exhaust, Transmission 2 03-10-2013 11:18 PM
What you want under the hood of a higher performance OEM variant of the AS1? MrVito BRZ First-Gen (2012+) — General Topics 26 12-26-2011 11:07 PM
