Old 04-07-2013, 02:02 AM   #1
shaoster
Drives: Toyota 86 GTS Man
Interior Dome Light in DOOR mode works in reverse!
Hey guys, I discovered that my door light does not function in DOOR mode at all, but I can turn it on and off. Brought it to Toyota for it to get repaired, but long story short, they rejected my warranty claim because I installed a drive camera by tapping it to the fuse for power and they claim it caused it which is bs cause it didnt work before i installed it, and hit me with a $1.6k fee to replace the ECU relay or something.
Anyway I didn't repair it and I just changed the stock bulb to the LED ones and it actually works in door mode, BUT in the opposite order. The light comes on when I close the door or lock the car, and turns off when I open it up.
Seeing how Toyota ain't going to repair it, anyone knows how I can reverse this in a DIY manner? Thanks in advance.
shaoster is offline   Reply With Quote
Old 04-07-2013, 02:37 AM   #2
Chaetagnath
Drives: Whiteout FRS
Remove anything you installed yourself (like your camera), take it to a different dealership, get it repaired under warranty.
Chaetagnath is offline   Reply With Quote
The Following User Says Thank You to Chaetagnath For This Useful Post:
Alfr-s (04-07-2013)
interior light DOOR mode not working shaoster Electronics | Audio | NAV | Infotainment 11 01-24-2020 04:10 PM
Map/Dome Light Dis-assembly/Phastek Performance LED Dome Light F1point4 DIY (Do-It-Yourself) Guides 9 03-25-2014 10:39 PM
Interior LED Dome Light Diffuser | DIY | 6X Brighter Dezoris Cosmetic Modification (Interior/Exterior/Lighting) 8 04-21-2013 09:59 PM
