Old 01-25-2013, 07:25 PM   #1
whtchocla7e
Drives: 2013 FR-S Hot Lava
Tach sweep is gone
After the mandatory ECU reflash, I no longer see the tach sweep after the ignition is turned on. Does anyone else notice this?
Live to drive another day
whtchocla7e is offline   Reply With Quote
Old 01-25-2013, 07:26 PM   #2
Tiremonkey0824
Drives: 2013 Argento 6mt
I thought only the brz did the tach sweep.
Tiremonkey0824 is offline   Reply With Quote
Old 01-25-2013, 07:27 PM   #3
whtchocla7e
My FR-S used to perform the tach sweep, too. I'm 100% certain.
Now I only hear the beep.
Old 01-25-2013, 07:30 PM   #4
akuhei
akuhei's Avatar
Drives: Raven M/T FR-S
Mine has never done the tach sweep.
Akuhei's Blog
"Inconceivable"
akuhei is offline   Reply With Quote
Old 01-25-2013, 07:33 PM   #5
Wes
Wes's Avatar
Drives: JRSC'd Asphalt FR-S
I didn't do a ECU reflash, but yes mine does do the tach sweep
Old 01-25-2013, 07:33 PM   #6
Laika
When In Doubt...
Laika's Avatar
Drives: Slowww
Car off, turn key to the position immediately before cranking it up*
Hit the ODO button a few times till you see "S OFF", hold the ODO button and it should change to "S ON".
*You may be able to do this without the key at all, I can't remember.
Join the Galaxy Blue Silica BRZ registry below:
https://docs.google.com/spreadsheet/...2c&usp=sharing
Laika is offline   Reply With Quote
Old 01-25-2013, 07:50 PM   #7
SubieNate
SubieNate's Avatar
Drives: 2013 FR-S Ultramarine
I think you have to have the shift light turned on for it to do it. It will sweep up to whatever RPM it's set to.
SubieNate is offline   Reply With Quote
Old 01-25-2013, 09:42 PM   #8
fistpoint
Drives: Supercharged Golf Cart
Read the manual folks...and do not put children into the washing machine(another manual tells you that).
fistpoint is offline   Reply With Quote
Old 01-26-2013, 12:50 AM   #9
Laika
When In Doubt...
Laika's Avatar
Drives: Slowww
I read this before, can anyone else vouch for this? I have my shift light set but my tach sweep still goes all the way.
Minor detail, just curious to learn about it.
Old 01-26-2013, 01:35 AM   #10
Vracer111
Vracer111's Avatar
Drives: '13 Nissan Frontier (4.0L 6spd 2WD)
FR-S sweeps to the RPM the shift light is set to while the BRZ does a full range sweep only...
Had a '13 FR-S Asphalt 6spd manual (bought new 5/25/12, sold 6/10/20) but needed to let her go... she will be missed.
Vracer111 is offline   Reply With Quote
Old 01-26-2013, 01:38 AM   #11
Laika
When In Doubt...
Laika's Avatar
Drives: Slowww
Now this makes sense. Thanks man!
Old 01-29-2013, 07:35 PM   #12
brianbot5000
brianbot5000's Avatar
Drives: White WRX Hatchback, Toyota Pickup
I *knew* there was a reason I spent an extra few thousand bucks on my BRZ - I get the full instrument sweep on start-up.
2013 Subaru BRZ, SSM Limited
vin: 6007xx
build: 3/2012
brianbot5000 is offline   Reply With Quote
Old 01-30-2013, 01:50 PM   #13
J-Money
J-Money's Avatar
Drives: GT-86
Mine does the Sweep.. FR-S No ecu problems cus im a boss.. got it in Sept
J-Money is offline   Reply With Quote
Old 01-30-2013, 01:59 PM   #14
norsamerican
norsamerican's Avatar
Drives: WRB BRZ
..buys car...throws owners manual in the trash...:facepalm:
HELP: Need Tach Signal!! Lil Abner Electronics | Audio | NAV | Infotainment 39 02-24-2016 08:59 PM
BRZ tach to FRS? lavisxice Cosmetic Modification (Interior/Exterior/Lighting) 7 04-01-2013 03:48 PM
Scion FR-S Tach Sweep Video F1point4 FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 7 06-15-2012 03:53 PM
plastic in front of tach feldy Cosmetic Modification (Interior/Exterior/Lighting) 8 06-10-2012 12:03 AM
Gauge Sweep? himbo BRZ First-Gen (2012+) — General Topics 17 12-12-2011 11:39 AM
