Old 12-13-2012, 02:11 AM   #1
ahaghshenas
ahaghshenas's Avatar
Drives: Subaru BRZ
Alternator pulley torque setting??
Got a full pulley set (crank, water pump, alternator), I know the torque settings for the crack and water pump but cant find the alternators torque recommendations anywhere.
Does anyone have any idea of what it might be or where I can find info on this??
Thanks
ahaghshenas is offline   Reply With Quote
Old 07-24-2014, 07:15 PM   #2
Anakin
Did you ever find out the torque specification for the alternator pulley nut ?
I really need to know this too.
Thanks !
Anakin is offline   Reply With Quote
Old 07-24-2014, 10:46 PM   #3
Jmonty
Realtor/ Principal Broker
Drives: JRSC BRZ GBS LTD 2010 LTD Outback
Wow that was a bump from the past, I will need this when I add my Raceseng S2 pully set that should ship next week
Jmonty is offline   Reply With Quote
Old 07-24-2014, 11:14 PM   #4
zkv476
zkv476's Avatar
Drives: 2014 SWP BRZ, MT
79.7 lbft according to the SM.
Suggestion in case you haven't already read about it, crack and tighten the bolts for the water pump and alternator with the belt still on and in 6th gear, otherwise it's a pain in the butt.
zkv476 is offline   Reply With Quote
Old 07-27-2014, 08:03 PM   #5
Anakin
Thanks for the info from the service manual !
I have 6 of the 11 (?) factory Subaru service manuals & I could not find this info & I looked until my eyes bled !
I emailed these manufacturers of aluminum alternator pullies & got the following responses on nut torque :
Perrin--------------- 55' lbs.
GFB ---------------- 60' lbs.
Beatrush ----------- 51.6' lbs. (70 Nm conversion)
Tomioka ------------ 80' lbs.
Someone stated that the alternator turns clockwise thus the nut is "self-tightening" ?
My gut is telling me to go with the 55' lb. torque setting since it is aluminum not steel as the factory one.
It bothers me that this pulley is not "keyed" in some fashion to the shaft to keep it from spinning.
Is the alternator shaft slightly tapered ?
The Tomioka pulley does not look tapered.
Anyway I have one of these coming : [ame="http://www.amazon.com/OTC-4475-Stinger-Grooved-Pulley/dp/B005J3KZPS/ref=sr_1_1?ie=UTF8&qid=1406506003&sr=8-1&keywords=otc+4475&dpPl=1"]Amazon.com: OTC 4475 Stinger Grooved Pulley Strap Wrench: Automotive[/ame] to hold the pulley for removal & installation; sure hope it works.
Traction/VSC Setting Preference ashtray BRZ First-Gen (2012+) — General Topics 27 08-24-2018 03:39 PM
how to change radio setting FRSowner Electronics | Audio | NAV | Infotainment 12 06-21-2013 10:20 AM
NEOPLOT Crank pulley Alternator pulley& Waterpump pulley ANREX Engine, Exhaust, Transmission 10 10-25-2012 07:45 PM
Alternator pulley?? xpicer Scion FR-S / Toyota 86 GT86 General Forum 2 10-13-2012 08:54 AM
Weak battery or bad alternator from factory? empower-auto Issues | Warranty | Recalls / TSB 2 09-21-2012 02:17 PM
