Old 08-22-2021, 07:01 PM   #1
uchiha
Drives: BRZ 2020
Check engine after drifting
Hi,
I've encountered a weird issue.
I was drifting with a low RPM (¬4K in AVG, sometime hit 6-7K for "fixes" but in general around 4RPM) for a relatively long time (maintained ¬2-3 minutes drift with couple of seconds stop between each drift, for around 20 minutes) and suddenly check engine light was on.
I'm after oil service, checked oil level - was good,
oil temperature was only slightly higher than regular drive (~around 140) .
Tried to turn the car off and start again, check engine was still on.
Turned the car off for around 20 minutes, started again - the light went suddenly off.
Any ideas what can it be?
Thanks,
uchiha is offline   Reply With Quote
Old 08-22-2021, 07:48 PM   #2
soundman98
ProCrastinationConsultant
soundman98's Avatar
probably something a code reader can tell you about
Old 08-22-2021, 11:23 PM   #3
whataboutbob
AutoX-10/10ths every run
The car keeps track of differences in wheel speeds. When you put a car on a dyno where the front wheels are not turning, but the rear wheels are it'll often throw a check engine light.
This could be a similar to the situation you've described where you were drifting and the front wheel speed was probably different than the rear wheel speed.
Typically this check engine light will self-clear after a bit of "normal" driving where the wheel speeds match.
There are at least 2 ways to determine if the check engine light is something to worry about:
1) Get a tool that will let you read the codes, and use the codes to figure out what is inducing the light.
2) Drive the car for a bit, if the check engine light is due to the differences in wheel speeds as I noted above, it'll auto-clear the check engine light after driving the car for a bit.
Build thread:Here
Check engine light then a traction control light then just a check engine... and then Jstyle Issues | Warranty | Recalls / TSB 13 02-15-2021 05:10 PM
Help! From check engine light to fouled plugs back to check engine + plugs refouling larchamb Issues | Warranty | Recalls / TSB 44 04-03-2016 09:39 AM
Check Engine light on @5.7k miles and engine stalling at 4,000 rpms? djdrugga24 Issues | Warranty | Recalls / TSB 3 06-25-2014 06:06 AM
Will I get a check engine light on if the engine bay has a direct injection failure? Astroboy Engine, Exhaust, Transmission 7 03-29-2014 06:16 PM
Engine sputtering while idling with check engine light flashing, WTF speedy racer Scion FR-S / Toyota 86 GT86 General Forum 15 08-27-2012 06:50 AM
