Old 09-26-2012, 11:08 PM   #1
white devil
Go Gators!
white devil's Avatar
Drives: FRS White-out "blown up"
snorkel removal?
Has anyone taken off there intake snorkel when you got an aftermarket intake?
"What do you mean I voided my warranty??"
FA20 Turbo + HRI Tune + FA20 Flex fuel + FA20club intake + SRT headerback exhaust + FA20 headers + KW3's + Hotchkis front and rear sway bars + Cusco strut tower bar + Perrin oil cooler + Perrin pulley & brake stop thingy + GFB water & alternator pulleys + Crawford air/oil separator
white devil is offline   Reply With Quote
Old 09-26-2012, 11:19 PM   #2
Burn
Slack Bum
Burn's Avatar
Drives: FT86
Yup, I did after I installed my airaid intake.. was kinda troublesome to take out the snorkel without taking out the front bumper down completely .. u can refer to this DIY post on how to take it out
http://www.ft86club.com/forums/showthread.php?t=15376
Burn is offline   Reply With Quote
Old 10-02-2012, 07:39 AM   #3
brichard0625
brichard0625's Avatar
Drives: 2013 Scion Frs(Scarlet)
i just took mine out but i dont have an aftermarket intake but i will be building my own and will probably be done by fri. I will say that the stock snorkel is way too small and not sure how the car even breaths better with it on. It was a pain in the ass to remove but i took of the rubber piece holding the bumper and pulled the bumper back just enough to unscrew the snorkel. I then removed the front park of the intake box so i can have a better grab at the snorkel. U have to have the snorkel at a certain angle and u have to use a little force to really get out tho. It was a pain in the a$$ without removing the bumper
brichard0625 is offline   Reply With Quote
Old 10-02-2012, 08:09 AM   #4
StarsGarrador
Gangnam Style Guru
StarsGarrador's Avatar
Drives: Suzuki GSXF650, WRB BRZ
Without an aftermarket intake you lose power when you remove the snorkel and leave stock. I'm on my phone now so I can't post the link but just search it. I took it out once i installed my Airaid intake, it was obnoxiously hard to remove but nothing like these damn side markers.
StarsGarrador is offline   Reply With Quote
Old 10-02-2012, 08:28 AM   #5
brichard0625
im building an intake and im doing a custom snorkel to the stock box.i dont think its been proving to lose power but with some educated guesses we believe it will suck in hot air with the stock box thus causing less hp and tq
Old 10-02-2012, 09:15 AM   #6
StarsGarrador
Gangnam Style Guru
I'll find the link to the dyno results when I get off work or if someone else can post that'd be awesome haha. Till then it looks like I'm blowing smoke..
Old 10-02-2012, 09:42 AM   #7
brichard0625
Just saw it and going to do some quick testing to see if it indeed sucks in hot air...just did a 15min run and logged my highest intake temp and lowest intake temp...going to let the car cool down and ill repeat the same process later and see what results we get. Either way i will be making my own snorkel that i hope benefits the intake and doesnt heat soak it...im going to keep the stock air box but im going to make the snorkel bigger. once im done ill post pics of the new intake
The Following User Says Thank You to brichard0625 For This Useful Post:
Style (10-02-2012)
Old 10-02-2012, 10:30 AM   #8
Style
LXXXVI
Style's Avatar
Drives: Dahlia (Raven FR-S)
Pls, I would like to know this as well, because I removed mine and am also in the process of building a DIY intake also.
Style is offline   Reply With Quote
Old 10-02-2012, 11:47 AM   #9
2forme
I've done this, the stock air box heats up quickly. Even the AIRAID sucks in some warm air, but not as much as a snorkel-less stock box.
Old 10-02-2012, 03:54 PM   #10
brichard0625
Ok so earlier on in the day i logged some data with the snorkel on and off..i drove around my block, hopped on the highway and did a full speed run and got off next exit and pulled up in front of my building. put the snorkel back on let the car cool down for about 30 mins and repeated the same run. Not sure why the pics on my phone keep coming up corrupted when i upload to pc but ill find a way to post them up. Without the snorkel my cars highest temp was 123.8 and lowest was 78.8 with the snorkel on my highest temp was 123.2 and lowest was 89.6..i do have an hks intake filter but it seems like without the snorkel it will breath better during wide open throttle but at idle it will get hotter..for now i have the snorkel off cuz its a b**** to take off and put back on
The Following 3 Users Say Thank You to brichard0625 For This Useful Post:
Future (11-22-2012), Norkoastal (10-03-2012), Style (10-03-2012)
Old 10-03-2012, 04:31 PM   #11
Style
LXXXVI
Style's Avatar
So you just have the drop in air filter correct?
Old 10-03-2012, 04:46 PM   #12
VSGTS14
987 Motorsports
VSGTS14's Avatar
Drives: '13 WO FR-S
the fix is to buy an intake that places the filter away from the motor. you're going to want some kind of fresh air ducting. otherwise, all that warm air from the motor is not helping.
VSGTS14 is offline   Reply With Quote
Old 10-03-2012, 05:32 PM   #13
JPxM0Dz
F Z1LLA
JPxM0Dz's Avatar
Drives: Lexus IS-F Series 2
I hear you on the side markers. Did you even figure out a better way of removal than manuals directions ?
2URGSE
JPxM0Dz is offline   Reply With Quote
Old 10-03-2012, 06:23 PM   #14
brichard0625
yessir...just a drop in...so i decided to do a little custom thing to the snorkel and it read a low of 75.2 today and a high of 123.2. Yesterdays weather was 64 with 88 humidity and today was 71 with 86humidity. So it was little hotter out today and i still managed to keep the intake even cooler now. Also with normal driving yesterday it read 88.2 at a constant speed of 60mph and today it read 80.6 at a constant speed of 60. Im not a expert with any of this stuff but i felt like doing my own little project and just using common sense and trying to make sure im not making the intake worse by taking in more hot air and so far im doing okay lol. i took some maf readings today and at idle my car read 3.9 and wot was 148.7g/s. If possible can anybody that has the torque app and stock air box take a reading for me.. Take a reading at idle and then if u can do a wot run in 3rd gear and tell me what your readings are
DIY: Antenna removal Hardrock4445 DIY (Do-It-Yourself) Guides 35 12-14-2021 10:00 PM
Airaid Intake Install with Snorkel Delete DIY W2 DIY (Do-It-Yourself) Guides 28 09-14-2016 05:42 PM
Badge Removal DetroitJake Cosmetic Modification (Interior/Exterior/Lighting) 5 10-01-2013 02:35 PM
WTB OEM Snorkel Spartan65 Engine, Exhaust, Bolt-Ons 1 10-20-2012 09:25 AM
snorkel removal Bu-Tang Engine, Exhaust, Transmission 4 09-01-2012 11:40 PM
