Old 08-29-2020, 04:13 AM   #1
jiffyjhn
Drives: White FR-S kosei k4r 17x8
Oil residue on underbody.
I was changing my oil today and snapped some pictures of the underbody where I see some oil residue. It’s close to the oil pan at the front close to the driver side. I noticed this a few months ago when I was installing aftermarket headers as well. It seems to come out of the driver side of the engine block, where top and bottom of the engine block are held together. There is some oil residue on the metal covering piece below the oil pan as well.
I drive the car quite hard but keep up with the maintenance as well. Anything to be concerned about?
jiffyjhn is offline   Reply With Quote
Old 08-29-2020, 09:17 AM   #2
alex87f
Meow
alex87f's Avatar
Drives: GT86 (now sold)
Timing chain cover ?
alex87f is offline   Reply With Quote
Old 08-29-2020, 10:36 AM   #3
DarkPira7e
Rust bucket enthusiast
DarkPira7e's Avatar
Probably your valve cover or timing cover. Could be several things- if you drop your engine shield it's probably full of oil. I'd take it somewhere to get it looked at
Old 08-29-2020, 12:34 PM   #4
kevtronzero
Drives: 2013 Subaru BRZ / 2011 Lexus ISF
Probably cam carrier leaking.
kevtronzero is offline   Reply With Quote
Old 08-29-2020, 12:49 PM   #5
ls1ac
ls1ac's Avatar
If it really bothers you, pull the shields clean well. Go to auto store barrow UV oil leak kit. Add the small vial of marker fluid and use the UV light and glasses to find the leak. It will work without cleaning but, well it shows better when clean.
Old 08-29-2020, 01:40 PM   #6
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
Clean off and check AVCS solenoids. They are sealed with an o-ring. Mine leaked there.
jiffyjhn (08-29-2020)
Old 08-29-2020, 01:50 PM   #7
jiffyjhn
Do you mean the oil pan shield(the big metal piece on the bottom)? I dropped that and it has oil on the side facing up but it wasn’t a lot. There is a thin layer with dirt stuck to it. I have some pictures from before when I was changing headers.
Old 08-29-2020, 03:17 PM   #8
soundman98
ProCrastinationConsultant
soundman98's Avatar
that looks like you drove through something! there's no air-to-oil cooler on these cars stock, so there's nothing forward of the belt assembly to oil those components!
Old 08-29-2020, 03:53 PM   #9
Grady
Grady's Avatar
Im I the only one that cleans their engine almost every oil change?
Old 08-30-2020, 12:34 AM   #10
Breadman
Breadman's Avatar
Drives: 2017 BRZ w/PP
this is the exact same leak as i have and my uv dye comes in tomorrow. im pretty sure it is the chain cover
The Following User Says Thank You to Breadman For This Useful Post:
jiffyjhn (08-30-2020)
Old 08-30-2020, 12:34 AM   #11
soundman98
soundman98's Avatar
what's an oil change?
The Following 3 Users Say Thank You to soundman98 For This Useful Post:
Grady (08-30-2020), JesseG (08-30-2020), NoHaveMSG (08-30-2020)
Old 08-30-2020, 01:47 AM   #12
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
This was mine. It was the AVACs solenoid on exhaust driver side.
Old 08-30-2020, 02:34 AM   #13
jiffyjhn
That looks similar. What did u do to fix it, replace o-ring?
Old 08-30-2020, 02:36 AM   #14
jiffyjhn
Would be cool if u can update what u find out from the dye. Thanks!
Sticker Residue Chop Shop Scion FR-S / Toyota 86 GT86 General Forum 23 09-12-2014 03:03 AM
Glue residue from delivery tape TRobb Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) 9 12-26-2013 04:02 PM
Clear bra left residue CamryDS Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) 3 08-09-2013 03:01 AM
Remove fingernail scratches and residue artizhay Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) 9 10-16-2012 12:28 AM
Removing white protective film residue enigmaaron Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) 10 09-22-2012 04:35 PM
