| Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) Everything related to the mechanical maintenance of the FR-S and BRZ |
Drives: 2023 BRZ
Magnetic oil drain plug advisable?
At this rate it will into September to hit 1K miles and a first oil change. Along with getting oil and a filter, I've seen references here to magnetic drain plugs -- I do not think I've ever had one on any car. So, (a) if one is a good idea, which one to get and where (part # and/or link would be appreciated, or (b) does the car come from the factory with one?
1964 Sunbeam Tiger, 2015 Porsche Boxster, 2023 Subaru BRZ
#2 |
Geo Tyrebighter Esq
Drives: '13 scion fr-s
FuMoto valve. You're welcome.
If you NEEEED magnets, a nyodium one on the filter will do.
"I gotta rock." -- Charley Brown |
| The Following 2 Users Say Thank You to bcj For This Useful Post: | soundman98 (08-12-2023), Spuds (08-21-2023) |
#3 |
ProCrastinationConsultant
i ran one for a little while.
it gets 'muck' around it. does it save anything? who knows. more frequent oil changes also would save things. after 3 oil changes, i got pissed off with it sticking to the metal oil pan on removal. it would stick just to the side of the opening, and then divert oil around wherever my drain pan is for the first 2 quarts until i could get enough expletives out, and an arm covered in oil to remove it fully to catch the remaining bit of oil. i changed to a fumoto valve and haven't looked back. in 3 oil changes, the valve has literally paid for the amount of oil dry i was needing to clean up my mess...
| The Following User Says Thank You to soundman98 For This Useful Post: | Spuds (08-21-2023) |
#4 | |
Drives: 2023 BRZ
Never had one, does it impact sound clearance?
#5 |
Famous Potatoes
Drives: '15 ultramarine
Stick with the stock plug. Works great.
| The Following 2 Users Say Thank You to Sapphireho For This Useful Post: | AJ32162 (08-13-2023), soundman98 (08-13-2023) |
#6 | |
![]() here's the clearance to the skidplate
#7 |
Wheels for Brains
Used to run a Fumoto. It got knocked loose at the racecourse, and I removed it.
I had a run-in with a rock on the road shortly after that. Thankfully it was removed, otherwise the rock would have ripped it off the oil pan --- The only thing a drain plug magnet would protect is the oil pump. Magnet on the filter is redundant since the filter membrane will catch all the metal shards that enter it; as long as it's replaced at a normal interval, it shouldn't release any metal into the engine block |
#8 |
Drives: FR-S,GTI
#9 | |
Drives: 2013 frs base
Magnetic plug? I don't remember iron filings listed on my oil analysis. |
#10 |
Famous Potatoes
| The Following User Says Thank You to Sapphireho For This Useful Post: | Ultramaroon (08-13-2023) |
#11 |
Fresh gaskets and gentle torque on the plug are, in the long run, much better than repeatedly cranking down on a work-hardened one.
| The Following User Says Thank You to Ultramaroon For This Useful Post: | soundman98 (08-13-2023) |
#12 |
Drives: 2017 BRZ PP, 2004 WRX
I've used a handful of various magnetic plugs on my WRX and BRZ. I will caution you against any cheap aftermarket plugs - especially with a magnet protruding far out into the oil a 1/2 or so. I've had one of these chunk off a piece and end up in the engine, filter, etc. Didn't do damage fortunately. It was a "Blox" brand, which isn't exactly a no-name eBay one either.
Subaru makes an OEM magnetic one that worked for my WRX. OEM and was a flat magnet. I run a Dimple brand magnet one that's essentially the same thing for my BRZ. Only real reason I changed it was the previous owner managed to start rounding off the OEM one. I have seen some minor debris/buildup on it since installing. Like a silver metallic goo. It's common if you run a magnet. These very fine particles would likely be picked up in the filter eventually. It's kind of overkill. I personally don't run a Fumoto valve because I autocross a lot. I could see it getting caught on a cone potentially under the car, even with the stock shielding under there. Maybe. Unlikely, but it's one less thing to worry about.
#13 |
The Dictater
Drives: '13 Red Scion FRS
I autocross with my fumoto valve with no issues. I have driven halfway across the country with a fumoto valve, no problems. I have done at least 12 oil changes with a fumoto valve (with a big-ole smile when I remember I have it and don't need to unscrew the plug), no problems.
The above again on my other car. Ok, I haven't autocrossed that... yet. I do like them valves though.
Also: "Build Thread" |
| The Following User Says Thank You to Spuds For This Useful Post: | blsfrs (08-22-2023) |
#14 |
Drives: FR-S,GTI
| Greddy Magnetic Oil Drain Plug + 10 Gaskets | skylinekin | Engine, Exhaust, Bolt-Ons | 0 | 12-27-2017 05:21 PM |
| Greddy Magnetic Oil Drain Plug or Fumoto Drain Valve? | tracerit | Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) | 20 | 01-04-2016 08:36 PM |
| Best magnetic drain plug? | FR-Sizzle | Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) | 18 | 09-28-2015 02:07 PM |
| Magnetic oil drain plug, effective? | BRZPDX | Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) | 7 | 02-17-2013 12:59 AM |
| Greedy Magnetic Drain Plug | USMC -FRS | Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) | 6 | 02-10-2013 07:04 PM |
