Old 01-26-2023, 09:59 AM   #1
Eff86
Drives: GT86
Battery drain due to removed antenna?
Hi all
New to this car... and because it is under a car cover, I removed the OEM antenna because it was getting bent.
Upon starting the car a few days later (with the antenna removed), the battery was completely DEAD.
Tried recharging it (with the antenna removed still) and an error indicated the battery won't hold its charge.
Could the removal of the OEM antenna have caused the drain and recharging error?
Thanks!
Eff86 is offline   Reply With Quote
Old 01-26-2023, 11:58 AM   #2
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
no
Wally86 (01-26-2023)
Old 01-26-2023, 01:54 PM   #3
JD001
JD001's Avatar
Drives: Subaru BRZ
I would say "yes" as ET may have been trying hard to call home but failing just because some thoughtless person took away the antenna...
The Following User Says Thank You to JD001 For This Useful Post:
NoHaveMSG (01-26-2023)
Old 01-26-2023, 03:53 PM   #4
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
I amended my previous response to..........
The Following 3 Users Say Thank You to NoHaveMSG For This Useful Post:
bcj (01-26-2023), JD001 (01-26-2023), x808drifter (01-27-2023)
Old 01-27-2023, 02:28 AM   #5
Eff86
Drives: GT86
So, reading between the lines, the battery is fried.
I didn't receive or feel any probes so we can exclude aliens.
Thanks!
Old 01-27-2023, 06:49 AM   #6
x808drifter
LMGTFY
x808drifter's Avatar
Drives: 13 FRS, 91 Miata
Considering the "bending" of the OEM antenna. 110% correct.
The Following User Says Thank You to x808drifter For This Useful Post:
NoHaveMSG (01-27-2023)
Old 01-27-2023, 08:56 AM   #7
Thanks!
HMMMM, as your profile states location as "Earth" which should be presumed by anybody from Earth and you are very eager to disregard aliens I suspect that you yourself may be an alien.
JD001 (01-28-2023), NoHaveMSG (01-27-2023), soundman98 (01-27-2023), x808drifter (01-29-2023)
Old 01-27-2023, 09:39 AM   #8
WNDSRFR
Drives: FR-S,GTI
Thanks!
No the battery is not fried.
Just recharge it. If it won't take a charge then hook it up in parallel to a good battery and put it on trickle charge.
The Following User Says Thank You to WNDSRFR For This Useful Post:
Old 01-27-2023, 11:03 AM   #9
WNDSRFR
Drives: FR-S,GTI
After you recharge the battery be sure to turn off your dome light.
The Following 3 Users Say Thank You to WNDSRFR For This Useful Post:
bcj (01-27-2023), soundman98 (01-27-2023), x808drifter (01-29-2023)
Old 01-27-2023, 12:10 PM   #10
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
Thanks!
Charge to full voltage. Have someone crank the car while you check voltage with a multimeter, voltage should drop out no more than 1.5-2 volts. If it drops out 2 or more the battery is on it's way out. Hold the gas pedal all the way down it won't start and will just crank. My guess is battery is likely on it's way out.
Old 01-27-2023, 12:14 PM   #11
FR-S2GT86
Master Collaborator
FR-S2GT86's Avatar
Hi all
Thanks!
My question would be:
Has there been any OTHER modifications or additions to the electrical system? Such as aftermarket stereo, alarm system, fancy under-dash lighting.
And as someone already mentioned, dome light possibly left on?
The antenna being removed would not cause a dead battery.
My pubes are shaped like the number 86. There for I’m car. Derp
Count to muffens and call again.
I’m 40. So....... say hi to your sisters or daughters.
FR-S2GT86 is offline   Reply With Quote
The Following 2 Users Say Thank You to FR-S2GT86 For This Useful Post:
Old 01-28-2023, 08:02 AM   #12
RZNT4R
Professional Mechanic
Drives: 2017 86 6MT Oceanic
Further:
Once you replace your failing battery, If you plan on having the car sit under a cover for extended periods of time, consider having a battery tender on the car while it sits. A hardwired NOCO 2D is a great option.
Old 01-28-2023, 09:12 AM   #13
soundman98
ProCrastinationConsultant
soundman98's Avatar
or unplug the battery. disadvantage is that you lose all your radio settings and the car needs to re-learn how to run.
Old 01-28-2023, 10:29 AM   #14
JD001
JD001's Avatar
Drives: Subaru BRZ
And, don't forget to stick the antenna back on as you don't want to run the battery down again...
antenna, battery, discharge, drain
battery drain along with dtc? _keepkushin_ BRZ First-Gen (2012+) — General Topics 2 09-20-2019 09:04 AM
Will staying in a turned off BRZ Limited drain the battery? btan219 BRZ First-Gen (2012+) — General Topics 33 04-21-2017 12:15 AM
Battery Drain from Dash-Rear Cams + Advice? covance Electronics | Audio | NAV | Infotainment 12 04-05-2016 12:08 AM
Does the bluetooth drain battery even when the car is off? lupindub Scion FR-S / Toyota 86 GT86 General Forum 6 07-30-2015 03:54 PM
Keyless fob and battery drain taiguy BRZ First-Gen (2012+) — General Topics 3 05-01-2015 09:49 PM
