Old 08-04-2014, 04:46 PM   #1
STS-V
C1231 - Steering Angle Sensor
Hi all,
Down to one final code - C1231; Steering Angle sensor fault. I've had the steering wheel on and off multiple times. Anyone know the correct way to fix this?
STS-V is offline   Reply With Quote
Old 03-29-2015, 06:07 PM   #2
redlined600
redlined600's Avatar
Drives: Fr-s
Bump - Any follow up on this?
@STS-V ?
redlined600 is offline   Reply With Quote
Old 03-29-2015, 06:14 PM   #3
Bobblehead
Bobblehead's Avatar
Drives: 2013 BRZ (gone) 2016 Ford Fusion SE
@STS-V ?
I don't want to be a jerk, but he got banned. I'm not sure if he'll ever see that.
Bobblehead is offline   Reply With Quote
Old 03-29-2015, 07:24 PM   #4
redlined600
Drives: Fr-s
Interesting, and is hardly call that being a jerk.
Either way, does anyone know if this code differentiates between a broken sensor and one that needs calibration or was installed incorrectly?
The Following User Says Thank You to redlined600 For This Useful Post:
Bobblehead (03-29-2015)
Old 10-24-2016, 12:29 AM   #5
the_comedian312
Drives: '13 BRZ 6MT Limited GBS
Did anyone ever figure this out because my '13 BRZ is spitting out the same code.
the_comedian312 is offline   Reply With Quote
Old 01-11-2023, 12:23 AM   #6
mike8o8
Drives: 2017 brz limited
i also have the same code left C1231 - Steering Angle Sensor
shows abs light and traction control light also
some help changed some parts lower control arm sway bar end link and wheel hub assembly
mike8o8 is offline   Reply With Quote
Old 01-13-2023, 10:13 AM   #7
Opie
Opie's Avatar
Drives: 2020 GMC Canyon Denali Diesel
This code appears for several reasons;
- the steering angle calibration is out of spec, can happen anytime a suspension component is changed, steering wheel removed, and/or if an alignment is performed and they skip the recalibaration steps.
- the steering angle sensor has a fault or is damaged, if you've had the wheel off are you sure you reconnected everything?, was the clockspring reinstalled correctly?
Diagnostic code(s): C1231
DTC detecting conditions: When the voltage at +BS terminal is between 9.6 to 16.5 V, a steering sensor error signal is received.
Common Faulty parts:
• ECM IG1 fuse
• Wiring harness or connector
• Steering sensor
CAUTION:
• When the steering sensor has been removed & or replaced, make sure to perform VSC(VDC) Centering Mode Calibration procedure.
• Before performing troubleshooting, check the fuse for this circuit.
Check wiring harness and connector (steering sensor power supply)
(1) Check the steering sensor connector for poor engagement or disconnection.
Criteria : No trouble
(2) Disconnect the connector D56 for the steering sensor.
(3) Check the case and terminal of the connector for deformation and/or corrosion.
Criteria : No deformation or corrosion.
(4) Check the voltage and resistance between terminals.
Voltage
Inspection terminals: D56-4(IG) - chassis ground
Inspection conditions: IG ON
Standard value: 11 to 14 V
Resistance
Inspection terminals: D56-1(ESS) - chassis ground
Inspection conditions: Always
Standard value: Less than 1 Ω
Captions in illustration
*a = Front side of vehicle wiring harness connector (Steering sensor connector)
If NG >Repair or replacement of wiring harness or connector
If OK >Replacement of steering sensor
2020 GMC Canyon Denali Duramax, 2021 Forester Sport, 2000 Subaru Legacy B4 RSK 5MT (JDM Import) and random 86 chassis rebuilds....
Opie is offline   Reply With Quote
Lack of steering angle? epson1 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 28 03-07-2017 03:00 AM
Stock FA20 Crankshaft Angle Sensor - Anyone know what type of sensor and output? Acree Engine, Exhaust, Transmission 2 08-26-2013 07:39 PM
Possible fix for lack of steering angle JordanWho Suspension | Chassis | Brakes -- Sponsored by 949 Racing 7 06-27-2013 07:51 PM
light steering angle improvement alexmotrix Suspension | Chassis | Brakes -- Sponsored by 949 Racing 8 03-17-2013 03:38 AM
