Old 12-13-2022, 10:07 PM   #1
Farrisj25
Drives: White
Crank but won’t start after replacing clutch
Hi everyone,
So I’ll try and make this short but I ended up replacing my clutch with a new throw out bearing and clutch fork all from act and versus since my throw out bearing went out from oem.
A few weeks after that it made some noise from the TOB and ended up taking it all back apart again got it back together and the car would crank but won’t start
Tried using ether and it wanted to crank over but just couldn’t..
(Note I did take the plate off from behind the FW. I made sure not to turn the FW when loosing or tightening as it did a little bit but not much)
So I took it all part to make sure I did everything correctly and I did so at this point I’m kinda stumped and done messing with it. Before I take it to a shop and spend $600 - $1000 what could this be and how can I save money and fix the issue?
If it’s the crank sensor and it got turned to much or whatever the case may be what do I need to do or is there to much involved and just have a mechanic deal with it?
Please send as much info as can.
Much appreciated.
Just fyi it started and ran fine before I took the trans off again.
Farrisj25 is offline   Reply With Quote
The Following User Says Thank You to Farrisj25 For This Useful Post:
humfrz (12-14-2022)
Old 12-13-2022, 10:27 PM   #2
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
Are you sure you put the reluctor wheel on correctly and not backwards?
FYI you also posted in the classifieds section.
Old 12-14-2022, 12:26 AM   #3
Farrisj25
Drives: White
Yes. Teeth towards the motor and not the fly wheel.
Old 12-14-2022, 12:27 AM   #4
Farrisj25
Drives: White
My bad I’m new here and didn’t know. Never posted on a forum before
Old 12-14-2022, 12:36 AM   #5
Originally Posted by Farrisj25 View Post
Hi everyone,
Much appreciated.
Hi ya, Farrisj25,
What "FW" are you referring to?
(Note I did take the plate off from behind the FW. I made sure not to turn the FW when loosing or tightening as it did a little bit but not much).
What did the crank sensor have to do with replacing the clutch?
I'm all
Old 12-14-2022, 01:02 AM   #6
Farrisj25
Drives: White
It’s a silver plate with teeth and holes in it. I’m just wondering if me taking off that plate would mess with the crank sensor. Since some videos I’ve watched said don’t take it off but I’ve seen some people take it off and it be fine. So I’m just clueless at this point why my car won’t start.
Old 12-14-2022, 12:18 PM   #7
Grady
Grady's Avatar
Possibly damaged the crank position sensor? Or something else. I would inspect everything in and around the transmission. From there disconnect the battery for a while to reset everything. Replace crank sensor.
Old 12-14-2022, 12:20 PM   #8
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
It's possible that it got damaged, but not probable. The cranks sensor is pretty easy to get to and it is not a super sensitive part to handling. Would be worth checking. You can ohm the sensor. Not definitive, but a check.
https://gt86stuff.onrender.com/t3Por..._rm_index.html
Are you sure it is in phase though? We have seen guys not get the reluctor wheel lined up with the pin on the crank before as well as having the reluctor backwards. I think the pin may be removable, not 100% sure. So it's possible it accidently got pulled out. It doesn't stick up that far and it is possible that you can tighten everything down over the top of it in place. Here is a thread where this happened.
https://www.ft86club.com/forums/showthread.php?t=130261
I would give everything a good double check before tearing anything apart, but this would be my guess. You may be able to pull the little rubber inspection port off the bell housing and have someone else crank the car to see if the reluctor or flywheel is wobbling. That would be a good indication of it being over the top of the pin.
Old 12-14-2022, 05:41 PM   #9
Farrisj25
Drives: White
I lined the wheel up with the what some call the lock pin where that wheel has a small hole in it but what concerned me was if that pin was smashed in or soemthing it sticks out very little. And when I disassembled it the 2nd time (when I double checked everything after it wouldn’t start. The pin was in the hole.
Old 12-14-2022, 08:26 PM   #10
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
Then I would check out the CPS like you originally thought, if that doesn't do it make sure everything is connected properly, DI driver bolted down tight.
Old 12-15-2022, 12:17 AM   #11
Farrisj25
Drives: White
If it is and if I do replace it with a new one. Will I need to do anything more serious or would I need to take it to a mechanic for them to reset everything and such. Not to familiar what happens if the CPS got off track or damaged
Old 12-15-2022, 12:36 AM   #12
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
No, it's a straight R&R. Not too hard to get to. Will be hard to see and touch at the same time. Manifold is a bit in the way.
Ultramaroon (12-15-2022)
Old 12-15-2022, 02:57 AM   #13
Farrisj25
Drives: White
Okay thanks. I mean it shouldn’t be too difficult then since I have the trans off and car jacked up atm.
Old 12-15-2022, 03:37 AM   #14
Ew... At least until it's cleaned up.
NoHaveMSG (12-15-2022)
engine won't crank after replacing battery Camnaka123 Issues | Warranty | Recalls / TSB 10 11-08-2020 05:31 PM
Crank but no start after clutch rep. RWD fun Engine, Exhaust, Transmission 27 06-20-2020 01:33 PM
Difficulty of replacing clutch (VS FWD car) RWD fun Engine, Exhaust, Transmission 8 06-15-2020 05:30 PM
replacing the crank pulley on automatic mrg666 Engine, Exhaust, Transmission 35 08-14-2018 07:20 AM
Replacing Scion FR-S start up screen hypercarfanatic Electronics | Audio | NAV | Infotainment 6 07-23-2014 03:46 AM
