Old 06-29-2022, 10:26 PM   #1
Natasha
Drives: 2018 brz ts black edition
Tail light fuse keeps blowing
my tail light fuse keeps blowing, unless my vland headlights aren’t plugged in. any ideas on what might be the problem? i’m very inexperienced as far as electrical issues go this is my first one on any of my cars.
Natasha is offline   Reply With Quote
The Following User Says Thank You to Natasha For This Useful Post:
humfrz (07-03-2022)
Old 07-02-2022, 03:30 PM   #2
thomasmryan
thomasmryan's Avatar
Drives: hyper blue
parking lamps or brake light fuse?
thomasmryan is offline   Reply With Quote
Old 07-02-2022, 06:02 PM   #3
soundman98
ProCrastinationConsultant
soundman98's Avatar
Well if the headlights not being plugged in stops blowing the fuse, I'd say it's the headlights.
The Following 2 Users Say Thank You to soundman98 For This Useful Post:
alphasaur (07-02-2022), humfrz (07-03-2022)
Old 07-02-2022, 07:29 PM   #4
alphasaur
friendly
Drives: 17' 86
Swap to OEM headlights, see if still blows. Ez.
Seek comfort in discomfort.
alphasaur is offline   Reply With Quote
Old 07-03-2022, 11:56 PM   #5
Welcome to ...... The Forum ..... there, Natasha -
If someone else swapped out your headlights, I suggest you take the car back to them and ask them to fix it.
If you are the one that swapped out the headlights, I suggest you take it into a shop and ask them to fix it.
BTW, which fuse keeps blowing? (position and amp)
Good luck.
Old 07-05-2022, 03:27 PM   #6
Natasha
Good luck.
thanks for your reply it’s a 10a fuse under the dash labeled “tail” i put them in myself and traded the oem headlights for these on facebook market place (not the best decision) i’ve asked 2 shops in my local area if they would look at it and they both said they don’t work on Subarus 🙄
humfrz (07-05-2022)
Old 07-05-2022, 07:33 PM   #7
thomasmryan
Drives: hyper blue
pull the parking light bulbs in both headlights and try again. if it blows the fuse it is in the wiring of the lamp. If the fuse does not blow, try new bulbs.
BRZ TAIL FUSE BLOWING 404dare Cosmetic Modification (Interior/Exterior/Lighting) 14 04-13-2023 09:25 PM
Fuse #4 Taillights Keeps Blowing epplecc Electronics | Audio | NAV | Infotainment 1 07-08-2021 07:12 PM
Tail/Fog/Plate light fuse keeps blowing leevanf BRZ First-Gen (2012+) — General Topics 5 09-07-2018 09:09 PM
4th brake light blew tail light fuse? wat? Xaftos Cosmetic Modification (Interior/Exterior/Lighting) 5 11-20-2017 04:06 AM
Running light "Tail" fuse in foot well keeps blowing **Fixed** paintdude258 Electronics | Audio | NAV | Infotainment 0 04-12-2017 04:59 PM
