Old 06-27-2022, 03:07 PM   #1
Sub1e26
Drives: 2017 Subaru Brz
Misfire on single cylinder with no check engine light
Hello all. Just wanted to see if I can get some help as I've been stressing my self out trying to find what's wrong with my car.. I have a
2017 supercharged brz. Car had 37k miles. I've been getting a single misfire on cylinder 3 but the misfire is only happening at cold start/idle. Once I drive my car and put it back to idle my misfire is gone. I'm not getting no check engine light so I can't go based off any code.. I've swapped out coil pack, spark plug and even threw in new injectors. Once My car is in drive the misfire seems to go away as well. I'm including 2 logs one at idle and one on normal driving. If anyone can help I would really appreciate it.
Sub1e26 is offline   Reply With Quote
Old 06-27-2022, 07:13 PM   #2
Grady
Grady's Avatar
how do you know you are having a misfire? What injectors did you replace?(PI, DI or Both?). Being modified I would look at the tune first.
The Following 3 Users Say Thank You to Grady For This Useful Post:
DarkPira7e (06-28-2022), humfrz (06-28-2022), Wally86 (06-28-2022)
Old 06-27-2022, 08:55 PM   #3
blsfrs
blsfrs's Avatar
Drives: 2013 frs base
My na FRS runs a little rough on cold start, no cel. I've been told it's because I have a lightweight flywheel. Not sure if it's true. Just repeating rumors.
Old 06-28-2022, 03:16 AM   #4
Single Cylinder Misfire B T Engine, Exhaust, Transmission 4 09-30-2021 03:01 PM
Check engine light then a traction control light then just a check engine... and then Jstyle Issues | Warranty | Recalls / TSB 13 02-15-2021 06:10 PM
Help! From check engine light to fouled plugs back to check engine + plugs refouling larchamb Issues | Warranty | Recalls / TSB 44 04-03-2016 10:39 AM
Will I get a check engine light on if the engine bay has a direct injection failure? Astroboy Engine, Exhaust, Transmission 7 03-29-2014 07:16 PM
Engine sputtering while idling with check engine light flashing, WTF speedy racer Scion FR-S / Toyota 86 GT86 General Forum 15 08-27-2012 07:50 AM
