| Software Tuning Discuss all software tuning topics. |
Drives: ZA1JA03N
Overrun fuel cut - ecutek How to disable it?
How to disable Overrun fuel cut using ecutek custom map?
#2 |
Drives: FT86
you dont need custom map
the stock table can effectivly disable overun fuel cut go to ecutek maps select folder Fueling then Overun open the Overun cutoff table This table shows the rpm at different coolant temps where the ecu re-enables fueling so if its got 1300 rpm means the ecu on overun stops fueling till rpm goes below 1300 so if you make those numbers big like 4000 it will fuel on overun to 4000. note you will increase fuel consumption as overun fueling is not an input to custom map it not easy to do in custom map |
| The Following User Says Thank You to steve99 For This Useful Post: | nerve86 (07-04-2022) |
#3 | |
Drives: ZA1JA03N
#4 | |
Drives: FT86
you dont need the custom map it will likely cause weird issues with idle when the ecu transitions from overun to idle mode you ill likely over fuel it if you use the custom map. all you need to do is change the standard overun fuel resume table, maybe dont male it 7000, 4000 is likey enough, assume your just trying to create some pops and bangs ? you can do that with just ignition retard in base timing at low loads |
| The Following User Says Thank You to steve99 For This Useful Post: | tomm.brz (07-05-2022) |
| E85 Overrun Pops & Fire on NA | erebuswarrior | Software Tuning | 33 | 02-25-2023 07:32 PM |
| 2018 BRZ - Window Overrun While Rolling Up | TurboLag23 | Issues | Warranty | Recalls / TSB | 8 | 05-22-2020 08:35 PM |
| Ecutek Overrun, Retard ign, flames. | Phoenix_gts86 | Software Tuning | 3 | 04-05-2020 04:17 PM |
| Can Ecutek disable diagnostic codes? | Kiske | Software Tuning | 3 | 05-16-2015 04:05 AM |
| ECUtek Flex Fuel REVOLUTION: World's First Flex Fuel Factory ECU GTR - BRZ soon! | Visconti | Engine, Exhaust, Transmission | 356 | 05-20-2013 09:36 AM |
