Drives: 2017 BRZ - WRB - PP
Uneven brake temps and warping after a light track day
I brought a laser temp gun to a track day for the first time. It was an SCCA "Track Night", so it was only three 20 minute sessions.
The first two sessions my rotor temps were still fairly low (about 250). As I was getting more comfortable for the last session I went a lot more aggressive. There was a large variation from L to R temperature was about 650 on the L and 450 on the R. The track does have more right handers under braking, but that still seems like a pretty large difference between left and right?! Another strange phenomenon occurred. Prior to the event my rotors were warped. Pretty bad vibration. I had them resurfaced once already and it didn't help for long, so I figured I'd abuse them and replace them after the event. Somehow the vibration almost complete vanished after the event. Did I somehow un-warp them? Last edited by imprezive; 04-17-2022 at 11:06 PM. Reason: Trying to direct more focus towards the uneven brake temps |
#2 | ||
ProCrastinationConsultant
TCS was interceding on your behalf to keep the car oriented. Quote:
https://alconkits.com/technical-info...ed-brake-discs
| The Following 4 Users Say Thank You to soundman98 For This Useful Post: |
#3 | ||
I did not disable ABS, but only felt it engage once or twice very briefly. Quote:
| The Following User Says Thank You to imprezive For This Useful Post: | gen3v8 (04-17-2022) |
#4 |
i believe the only change from '17+ was a less intrusive track mode. i believe press-hold still is the same, where tcs is still active, just the least intrusive mode.
#5 |
30 minute maintenance
Drives: My18 wrxsti
I run my 2017 long press. No probs very minimal intrusion. No brake overheats unless by ME. May I add I get around my local Track fairly Fast but only in comparison to other drivers. Then again ABS is not my concern, Nannies stopping me from getting on the gas are !.
#6 | |
Drives: '23 BRZ
https://practicalmotoring.com.au/car...baru-brz-work/ Last edited by ZDan; 04-17-2022 at 09:02 AM. |
| The Following User Says Thank You to ZDan For This Useful Post: | soundman98 (04-17-2022) |
#7 | |
| The Following User Says Thank You to soundman98 For This Useful Post: | NoHaveMSG (04-21-2022) |
#8 |
Drives: '23 BRZ
#9 |
Because compromise ®
Drives: Red Herring
I read this post and scratched my head. Huh? I don't understand. I went back and reread your first post in this thread then spotted the link. It was quite well camouflaged and it wasn't surprising I didn't see it on my first read through. Admittedly, I cringed a little when I spotted the link.
My apologies.
| The Following User Says Thank You to Captain Snooze For This Useful Post: | soundman98 (04-17-2022) |
#10 |
Sometimes I'm wrong.
Drives: '13 FR-S/'96 240SX
I notice I've been sitting in traffic too often when I start to get brake judder. "Spirited" driving usually fixes it.
#11 |
Its more of un-even pad deposit on the face of the rotor vs wrapped rotors. And Chances you "bedded" your brakes while on track which got rid of the even pad deposits.
2013 Series 10 FRS #553
| Are these track coolant temps acceptable? | TheRealBFKR | Tracking / Autocross / HPDE / Drifting | 2 | 05-31-2021 06:06 PM |
| DIY:Valenti 3rd/4th Brake Light Mod-Separate Brake light Triangle-2 Options -Video | continuecrushing | DIY (Do-It-Yourself) Guides | 44 | 11-23-2020 06:17 PM |
| Deciding on a brake pad for light track use | rkaywhodat | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 11 | 02-01-2017 10:58 PM |
| Worried about 1st track day oil temps | cookiesowns | Tracking / Autocross / HPDE / Drifting | 74 | 07-13-2015 12:00 PM |
| Brake disc warping patterns | Strat | AFRICA | 12 | 04-02-2015 07:05 AM |
