Old 04-19-2022, 10:01 AM   #1
Martijn
Drives: Orange 2012 GT86 automatic
rattle left rear side
Dear All,
We have bought a 2012 GT86 automatic just a couple of weeks ago. We love the car and is a well fitting addition to our Camry and 2004 MR2.
At higher speeds (100kmh / 60MPH, +) a rattling sounds occurs. It does not sound mechanical but more random. The sounds seems to come from the rear left side and seems to become louder with changing driving direction (up the road or down the road) and or stronger with higher wind speeds. I have checked in several gears and this does not affect the sound. I have checked the underside of the car and could not find any loose heat deflectors or something similar. The only thing I could find being a bit wobbly is the piece of plastic trim (part of the inside of the rear wheel arches) sticking out in front of the rear tire. (door side) I think it is a kind of water or whatever deflector.
I could not find any screws to tighten this. Now my questions:
Does this sound familiar to you?
Could this be our noise?
How to tighten or fix the rattle?
Many thanks in advance for your thought tips and tricks and regards from the Netherlands!
Martijn is offline   Reply With Quote
Old 04-19-2022, 05:28 PM   #2
S_Yogurt
Drives: '13 Scion FR-S, '12 Ford Fiesta
I had a rattle that was driving me insane, turns out my taillight housings weren't bolted tight.
I had my rear bumper repainted and the bolts loosened themselves since they were just hand tight. Probably isn't it but worth checking, since mine seemed sort of random and was worse at higher speeds, and was distinctly in a rear corner.
S_Yogurt is offline   Reply With Quote
Old 04-19-2022, 08:51 PM   #3
https://www.ft86club.com/forums/showthread.php?t=42065
Old 04-21-2022, 04:09 PM   #4
Martijn
I will check that, many thanks for the tip.
Old 04-21-2022, 04:11 PM   #5
Martijn
Many thanks for the link also worth while checking.
Old 04-21-2022, 05:02 PM   #6
Yep. It was a very common complaint back in the day
Old 04-22-2022, 12:11 PM   #7
Sasquachulator
Pavement Grey
Might be a different kind of rattly noise, but one time i found out my rear seatback wasnt secure properly on one side in the upright position.
Had to drop it down again and really slam it back to secure it on both ends.
Old 04-22-2022, 03:03 PM   #8
tarzan_nojane
tarzan_nojane's Avatar
Drives: 2014 FR-S
Several years ago my '14 had an annoying "rattle" at higher speeds that was caused by missing fasteners on that deflector piece you described (mine was on the right). One of the holes in the part was actually torn, and I believe I added a larger plastic washer to assist the plastic fastener in securing the deflector to the sheet metal.
tarzan_nojane is offline   Reply With Quote
FS (CA): OEM Rear Taillight, Never mounted, Left side only Eric_FRS Exterior Parts (Aero, Lighting, Etc.) 0 02-17-2016 06:08 PM
That left-side vertical streak of residue left by windshield wipers tzhu07 Scion FR-S / Toyota 86 GT86 General Forum 20 07-15-2015 01:23 AM
WTB Red Bumper, Left Fender, Left head light, Clear side markers carlossanchez89 Want-To-Buy Requests 0 09-01-2014 04:43 PM
Left Door Rattle Jigglybus Electronics | Audio | NAV | Infotainment 4 07-11-2014 12:35 PM
Rattle in rear left of car - Need some help! eleu2166 AUSTRALIA 4 12-01-2012 10:51 AM
