| Software Tuning Discuss all software tuning topics. |
Drives: 2017 Subaru BRZ (silver)
Tune for Stg2 E85 with 650Injectors
Car is currently tuned to run my Vortech kit with 650injectors. Although I've pulled the blower to change a seal and get some powder coating done, but I'd still like to drive the car in the meantime and would easily be able to flash a Stg2 E85 tune, if it wasn't for the injectors.
Either that, or I'm assuming the tune is safe I'm running for the Vortech, I would just need the MAF retuned for the OEM air intake and the car would run as if I'm not into boost, at least that's my assumption. Any advice or ROM tables I can copy, or willing to adjust the tune themselves for some $$? Thanks in advance. |
#2 |
Drives: brz 2017 hksv2
sent you a PM i can help you
#3 | |
Drives: FT86
If you have a vortech SC tune in ecu for 650 injectors and map sensor and E85 and you just removed SC and same injectors map and fuel then fine to drive car on the SC tune without the SC fitted. the maf scaling might be off a bit but running a boost tune when NA is fine assuming same injectors and map sensor still fitted and running same fuel |
| stock MAF correction tables are ok to put on stg2 v4.03 with catted header | oBradyG | Software Tuning | 1 | 09-29-2021 09:06 PM |
| Difference of OFT Stg1 vs Tomei+Stg2 | leevanf | BRZ First-Gen (2012+) — General Topics | 5 | 03-04-2018 03:10 PM |
| which OFT map file to use? BPB stg2 | Corradooo | Software Tuning | 2 | 06-29-2014 05:09 PM |
| [review]Stay away from Ecutek FA20 tune(stg2) if..... | WatchmaN | Engine, Exhaust, Transmission | 46 | 06-06-2014 05:57 PM |
| FT-86 STG2 Brake Kit VS Wilwood 4R Slotted Front | jflogerzi | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 16 | 06-10-2013 08:33 PM |
