Drives: 2013 FRS
AT paddle shifters and floor shifter not working
Hi my auto FRS paddle shifters or floor shifter wont work when put in the "M" option
It will let me down shift using the floor shifter but wont let me upshift when reaching higher speed and rpms. In rare cases it will engange to upshift after 30 or so attempts. Paddle shifter not working at all. |
#2 |
Drives: 2013 Raven
How long have you had the car? Have you done any mods? Will it stay in "M" or does it go back to "D". You might want to check the transmission fluid level.
On the contrary, my paddles work fine, but the gear shift will only shift to a higher gear. The downshift does not work at all. It started going out when the shift boot would get in the way of downshifting. My theory is that some fibers from the synthetic material became trapped inside the mechanism as I could reach in a clean out the inside of the gear shift from the hole that was worn in the gear shift boot. This would help temporarily, but not anymore. |
#3 |
Welcome to the forum ......
![]() You might check the AT fuse (which is a 15 amp fuse, in position #16, in the fuse block under the dash). humfrz |
#4 |
Drives: 2013 FRS
Ive had the car since 2012 its a 2013
has mild mods (intake,headers,exhaust,flexfuel) but the issue started before that. have not change trany oil since i also checked the fuses and they are goood it aldo stays in "M" but wont shift up only down and paddles dont do anything |
| The Following User Says Thank You to areyesFRS For This Useful Post: | humfrz (11-06-2017) |
#5 |
hmmm........maybe the AT's computer needs to be re-flashed ......
![]() humfrz |
#6 |
Drives: 2013 Raven
Mine is the same age. And I have the same mods except for the flexfuel. Sounds like something with the electronics for sure. Have you tried Sport, TSC off, etc and see if there is anything different with the shifting. You haven't added an AT cooler? I believe Mr. Blue had some shifting issues after adding a cooler, but it was because of some 90-degree connectors. I'm really hoping we can figure this out. I'd like to be able to downshift with the gear shift too, but I'm not to concerned since I can still use the paddles.
#7 |
Drives: 2013 Raven
Did you ever figure this out? Toyota will warranty the repair of my gear shift so that I can downshift. Covered under powertrain 60k.
#8 | |
Drives: 2013 Raven
#9 |
Drives: FRS
#10 |
Drives: 2013 Raven
| Paddle Shifters 101 | SquadRogue | Scion FR-S / Toyota 86 GT86 General Forum | 38 | 03-04-2015 11:05 PM |
| Them Paddle shifters? | Broninjas | Scion FR-S / Toyota 86 GT86 General Forum | 18 | 06-19-2014 02:07 PM |
| How do I use my paddle shifters? | nerb | Other Vehicles & General Automotive Discussions | 13 | 02-17-2013 08:10 PM |
| paddle shifters | Sasquachulator | Scion FR-S / Toyota 86 GT86 General Forum | 11 | 08-28-2012 11:15 PM |
| Paddle-Shifters | Buggy51 | Scion FR-S / Toyota 86 GT86 General Forum | 45 | 09-14-2011 01:20 AM |
