Old 03-05-2022, 12:28 AM   #1
eyeballs
Drives: '22 BRZ
mud guard instructions
Supposedly you get them from the dealer, but mine said they didn't exist. I put the fronts on which were pretty straightforward, and will look at the rears once I swap my summer tires on. Just curious if anyone had seen them, as I figure it'll save me a few minutes having the instructions.
eyeballs is offline   Reply With Quote
Old 03-15-2022, 01:36 AM   #2
eyeballs
Drives: '22 BRZ
Rears take more work then the fronts. Inner hole in the liner and lower rear hole need to be drilled large enough to accept the pop fasteners (at least that's what I did). Rear hole location already has a small indent from the factory. I had to swing open the caliper to get enough clearance for my drill. I was careful not to make those holes any larger then needed to be to accept the plastic fastener.
Old 03-15-2022, 06:56 AM   #3
Wally86
Be Kind
Wally86's Avatar
Drives: 2020 86
https://www.ft86club.com/forums/showthread.php?t=21425
Link to the PDF in there too.
[Insert clever signature here]
IG | WhiskyBlog | Photography
Wally86 is offline   Reply With Quote
Old 03-17-2022, 01:21 AM   #4
eyeballs
Drives: '22 BRZ
2nd gen is totally different design.
Old 03-17-2022, 05:42 AM   #5
Wally86
Be Kind
Wally86's Avatar
Drives: 2020 86
Completely my bad. I didn't even notice this was the 2nd gen section
Here are your Rocketbunny instructions! Maverick22 Cosmetic Modification (Interior/Exterior/Lighting) 35 04-03-2017 12:52 PM
BaysonR sti sideskirt instructions?! nickmerronesucks Cosmetic Modification (Interior/Exterior/Lighting) 4 10-17-2014 01:04 AM
Modellista Antenna Instructions Pvt AJ DIY (Do-It-Yourself) Guides 22 06-16-2014 09:06 PM
Instructions to install OEM mudguards? eddieEndo DIY (Do-It-Yourself) Guides 7 02-13-2013 04:18 PM
Instructions for dash disassembly whataboutbob Cosmetic Modification (Interior/Exterior/Lighting) 3 07-01-2012 07:03 PM
