Old 12-14-2021, 07:48 PM   #1
nowakmar
2013 BRZ engine code P0016
Hey guys,
Just have a quick question.
Recently my 2013 BRZ with 140K kilometers has thrown a P0016 engine code. After about two weeks of troubleshooting, my local Subaru dealership told me that my cam sprocket needed to be replaced but they also said that it could be the ECM. They have gone ahead with replacing the sprocket, sadly that didn't fix the issue and now the want to replace the ECM.
Does this makes sense, could both the sprocket and ECM be causing the engine code simultaneously or did my dealership replace the sprocket unnecessary?
Your input is greatly appreciated.
M.
nowakmar is offline   Reply With Quote
Old 12-14-2021, 09:05 PM   #2
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
Ahhhhhhhhh the dreaded P0016.
Supposedly the learning values can get way off in the ECU and there is no way to reset it which necessitates the ECU replacement. I remember somebody allegedly put a different ECU in his car then switched back and it fixed itself or something. It was a long time ago.
Here is a long read on it. It has bitten an unfortunate many.
https://www.ft86club.com/forums/showthread.php?t=123459
The Following 2 Users Say Thank You to NoHaveMSG For This Useful Post:
ShadowReaper (12-04-2024), Tcoat (12-15-2021)
Old 12-15-2021, 08:58 PM   #3
nowakmar
Thanks for the reply.
2013 FR-S with CEL, code is P0016. What should I do? 7onasL Issues | Warranty | Recalls / TSB 7 11-18-2025 11:39 AM
Help with disable a code P0016 on a OFT Aace Software Tuning 9 03-06-2019 08:56 PM
P0016 Code Shady195 Engine, Exhaust, Transmission 30 02-21-2019 03:31 PM
HELP code P0102 engine goes on and off aldo29199 Engine, Exhaust, Transmission 5 07-26-2016 08:57 AM
P0328 Engine Code Lil Abner Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 28 10-23-2014 01:10 PM
