Old 08-21-2018, 10:53 PM   #1
shadow_772
Drives: 2014 BRZ Limited
Oil leak? Front driver side
I popped the hood today and noticed that the driver side had a build up of oily crud (for lack of a better term) coating the skidplate. From there I noticed a light build up on everything above it leading all the way back to the firewall.
Dipstick shows no oil loss, but I'm not sure how accurate they are on these cars.
Car has 55k miles and is stock.
Anyone have a similar experience?
shadow_772 is offline   Reply With Quote
Old 08-22-2018, 11:27 AM   #2
hyper4mance
hyper4mance's Avatar
Drives: 13 BRZ, 97 e36 M3 Rides: '07 600RR
http://www.ft86club.com/forums/attac...1&d=1413834741
I have it as well, haven't serviced or fully diagnosed it yet but its a common issue. Take a look around as shown in the pdf to see where it might be coming from.
hyper4mance is offline   Reply With Quote
The Following 2 Users Say Thank You to hyper4mance For This Useful Post:
shadow_772 (08-22-2018), Tcoat (08-22-2018)
Old 08-23-2018, 08:06 AM   #3
gravitylover
I'd get it into a dealer and have them figure it out before you hit the 60k mark when your engine warranty runs out. I, and many others, had the timing cover leak and the fix would have been silly expensive if it wasn't covered.
Old 08-23-2018, 09:24 PM   #4
stevesnj
stevesnj's Avatar
Most likely spilled oil from adding oil. The fill spout is low and even with a funnel will drip down near the cam sensor covers to the skid plate.
My 2016 Build thread
Old 08-23-2018, 11:34 PM   #5
shadow_772
I'm not the original owner :[
I'm considering that. I'm usually very careful, but who knows. I'm going to get the engine bay spotless and see if it comes back.
Old 08-24-2018, 10:44 AM   #6
stevesnj
stevesnj's Avatar
Doesn't matter if you're not the original owner. The warranty covers the car powertrain regardless of owner.
The Following User Says Thank You to stevesnj For This Useful Post:
Wally86 (11-02-2021)
Old 08-26-2018, 01:03 AM   #7
shadow_772
You learn something new every day! Thank you, I'll verify it is actually seeping and go from there!
The Following User Says Thank You to shadow_772 For This Useful Post:
Old 08-28-2018, 05:02 AM   #8
guybo
Huge E85 fan!
guybo's Avatar
Drives: 2016 Scion FRS
Most likely it's just the cam plate cover- common problem, covered under warranty
guybo is offline   Reply With Quote
Old 08-30-2018, 04:23 PM   #9
kch
Senior Misanthrope
kch's Avatar
Cam plate is on passenger side. It sounds like OP has a timing cover leak, which is also a common issue.
Old 10-08-2018, 01:12 PM   #10
BestFRS
Drives: 2013 FRS
I have the oil leak issue and dealer had reseal the timing cover, cam cover 3 times and it is still leaking. The motor is now removed from my car and the dealer is working with Toyota to identify where the leak is cominf from. It's been almost a week in the shop and there is no words on completion.
BestFRS is offline   Reply With Quote
Old 10-12-2018, 02:29 PM   #11
chaoskaze
The Fail Boat
chaoskaze's Avatar
Drives: CWP S.B.
I have this issue as well, problem is now my warranty is expired already.......
*I actually noticed the issue before warranty expires @ 59k miles, took it to dealer & they only replace the VVT control unit on the top right cuz there was obvious leak mark from there.
It's still dirty & leaks but now I'm not in warranty@64k mile I guess there is nothing i can do now except build engine?......
Old 11-01-2021, 07:34 PM   #12
CockpitCruiser
Custom Title
CockpitCruiser's Avatar
Drives: GT86
same issue - pretty slow leak on mine tho - thanks for the info - nice to know
Eat, Sleep, Drive, Work, Drive, Ride, Eat, Sleep. Repeat
CockpitCruiser is offline   Reply With Quote
Driver side valve cover gasket leak solidONE Issues | Warranty | Recalls / TSB 59 02-22-2021 01:52 AM
Oil Leak on driver side EINSTEIN562 Issues | Warranty | Recalls / TSB 3 08-09-2020 01:16 PM
WTB: FRONT Driver side LCA Jpizzle0621 Want-To-Buy Requests 1 08-23-2017 02:34 PM
WTB> 2013 (WHITEOUT) OEM Front Bumper/Side Fender (Driver's Side) eddieEndo Want-To-Buy Requests 0 06-20-2017 12:22 AM
oil leak, drivers side, front of engine carbonBLUE Issues | Warranty | Recalls / TSB 41 10-03-2015 12:51 AM
