Old 10-17-2021, 02:17 AM   #1
DjDATZ
EightSixClub Co-Founder
DjDATZ's Avatar
Drives: Selina (FR-S), Rondo EX V6 & fortwo
Trunk Cancel Button Pressed, But Lock Seized
Earlier this week, my trunk stopped opening from the cabin button and the remote. I've had this happen before, so I know I can just unlock the trunk from the lock above the license plate.
However, when I went to try that, it seems the lock has seized. I tried WD-40ing it to get it to release, but no dice. I tried rotating the key so hard that I apparently warped it so much, that I couldn't turn the ignition. (Simple solution to that, I just warped it back.)
Given that I don't want to destroy a key, what suggestions that I can try to get it to release? I could try reaching in to get to the straps behind the back seat to see if can pull on them to fold the seat down. Suggestions on how to do this?
Sent from my HD1905 using Tapatalk
Meet Selina, my Asphalt FR-S MT6.
Like EightSixClub on FB, and follow us on Twitter!
DjDATZ is offline   Reply With Quote
Old 10-17-2021, 02:27 AM   #2
villainous_frx
Off to the track!
villainous_frx's Avatar
Drives: '14 Lava 86, '13 WRB BRZ
Shove your hands through the back seats and pull the rear seat release strap(s). Then get a 3D printed button cover and never worry about it again!
villainous_frx is offline   Reply With Quote
The Following 2 Users Say Thank You to villainous_frx For This Useful Post:
DjDATZ (10-17-2021), JohnH (10-20-2021)
Old 10-17-2021, 02:30 AM   #3
DjDATZ
DjDATZ's Avatar
Tried that, my hand gets stuck at the wrist Will ask the fiancée to try ahah
Will take a look for the button cover, duct tape will do temporarily!
Old 10-17-2021, 04:39 AM   #4
villainous_frx
Off to the track!
Using a piece of wire, such as a coat hanger has also worked for me in the past. Good luck!
Old 10-17-2021, 07:30 PM   #5
DjDATZ
DjDATZ's Avatar
She couldn't get her hand in and I tried a bunch with a coat hanger and nada.
Old 10-17-2021, 07:51 PM   #6
soundman98
ProCrastinationConsultant
soundman98's Avatar
did you try pushing down on top of the trunk while trying to turn the key? sometimes it relieves enough pressure in the lock assembly to allow it to work.
JohnH (10-20-2021)
Old 10-17-2021, 08:36 PM   #7
RZNT4R
Professional Mechanic
Drives: 2017 86 6MT Oceanic
You're either going to have to get to the straps with some sort of hook, or take out the seat seat cushion, and move the rear side trim our of the way enough to remove the bolts holding the seatback hinge to go through from under.
But on an unrelated note, I was looking at your profile trying to see what year it was for the trunk cylinder to seize from corrosion, and while the year isn't listed, I see you're in toronto with a Kia Rondo...
... Get rid of that hot potato SOON. if you're in canada your cars are subject to rust and those kias have STRUCTURAL FUEL TANKS which are weak to rust, the start to leak from the bottom and cost several thousand dollars to replace.
The Following 2 Users Say Thank You to RZNT4R For This Useful Post:
DjDATZ (10-18-2021), soundman98 (10-17-2021)
Old 10-17-2021, 09:10 PM   #8
villainous_frx
Off to the track!
2014 here and formerly winter driven, still need to take it apart and clean everything out of it
Old 10-17-2021, 09:17 PM   #9
You may be able to pull up the two "buttons" on the top of the back seat. Those are the latches. As I recall they basically work like door locks.
humfrz (10-20-2021)
Old 10-17-2021, 09:55 PM   #10
AJ32162
Drives: 2019 BRZ with Performance Package
This may help it's from a post by Stang70Fastback on another thread.
"Grab the black plastic trim surrounding the lock mechanism on the top corner of the rear seatback. Pull it up. It snaps right off. The pull up on the red-colored peg to release the seat. Then just snap the cover back on. It's that simple."
AJ32162 is offline   Reply With Quote
The Following 3 Users Say Thank You to AJ32162 For This Useful Post:
DjDATZ (10-18-2021), JohnH (10-20-2021), soundman98 (10-17-2021)
Old 10-17-2021, 10:21 PM   #11
Yep, that's basically what I was saying, without the detail.
Old 10-18-2021, 12:57 PM   #12
DjDATZ
DjDATZ's Avatar
Thanks for the tips y'all, will give them a try when I have a little time today!
Old 10-18-2021, 12:59 PM   #13
DjDATZ
DjDATZ's Avatar
Selina's a 2013 FR-S, got her August 2013!
The Rondo is on its way out, had a spate of a few weeks of going in and out of the mechanic's shop for various repairs. Third time replacing the water pump in about a year and a half. IIRC it's a 2012 or 2011?
Old 10-18-2021, 04:45 PM   #14
DjDATZ
DjDATZ's Avatar
Worked like a charm, thank you! Now to find that button cover and get it ordered!
The Following User Says Thank You to DjDATZ For This Useful Post:
Jdmjunkie (10-18-2021)
Seized motor/vapor lock after installing Edelbrock 1556 iceblaze Forced Induction 26 12-28-2018 11:24 PM
Trunk button or fob trunk button aren't working. kamilehaula Issues | Warranty | Recalls / TSB 10 10-24-2018 08:33 AM
disable the trunk release cancel button Riftur Electronics | Audio | NAV | Infotainment 19 02-13-2016 01:35 PM
Buzzing/popping sound when HID fog light button is pressed. HELP! gabrielthethird Cosmetic Modification (Interior/Exterior/Lighting) 3 02-08-2015 11:10 PM
when you hit the lock button on your key... pr086 Scion FR-S / Toyota 86 GT86 General Forum 15 11-28-2012 01:55 AM
