Drives: 2014 BRZ
Locktite on brake caliper bolt threads?
I'm changing out the brake pads on my 2014 BRZ. When re-installing the two bolts that attach the caliper, should I put locktite on the bolt threads?
There are people online claiming both sides - either the world will end without locktite on those bolts, or it doesn't matter. What are you guys doing? And also is 19ftlbs the correct amount to tighten the two caliper bolts? Thanks for any advice. |
#2 |
Drives: 2014 BRZ
Searching through more threads here, I found this nice writeup:
https://www.ft86club.com/forums/showthread.php?t=24614 That and other threads confirm the 19ft lbs caliper bolt torque. But that and other writeups here on site, do not mention any use of loctite, anti-seize or other compounds on the caliper bolt threads. So I'm probably going to not use anything on the threads. Unless someone or Subaru recommends something, please let me know. |
#3 |
Drives: 17 Asphalt 86
I've never heard of using loctite on caliper bolts. Just torque them to spec and you'll be fine.
#4 |
Drives: '13 FRS - STX
About 25k miles since I last touched my calipers to swap pads, 25k before that, ~100k miles on the car total, brakes have been on and off about a dozen times, never used loctite.
| The Following User Says Thank You to strat61caster For This Useful Post: | norcalpb (06-01-2021) |
#5 |
The screws, threads, and the associated mating surfaces are specified and manufactured to tolerances such that, if they were ever to come loose with, or without thread locker, there would be much worse things to worry about.
Unless the service manual specifies thread locker, there is no need.
#6 |
Famous Potatoes
Drives: '15 ultramarine
I'd be going with a fine bit if anti-seize before loctite.
| The Following 3 Users Say Thank You to Sapphireho For This Useful Post: |
#7 |
Drives: 14 BRZ SWP
I don't think loctite would even help due to the heat.
According to the Technical Data Sheet, Loctite (blue) has an upper service temp of 300F. Moderately heavy brake use could certainly heat the calipers to above 300F. https://dm.henkel-dam.com/is/content...-2018-04-09pdf |
| The Following User Says Thank You to AT-JeffT For This Useful Post: | timurrrr (06-01-2021) |
#8 |
ProCrastinationConsultant
I don't like the idea of locktite on threads that close to the sliders. Too easy to accidentally get some on the sliders and mess up a set of pads. Of course I wouldn't know about it until I need a brake job at 10k miles
| Brake Pad for Dual Caliper Hydro e Brake | Katsu | Tracking / Autocross / HPDE / Drifting | 14 | 05-22-2020 03:52 AM |
| Stoptech S/S brake lines: same between stock caliper vs big brake kit? | mav1178 | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 11 | 05-10-2016 08:14 PM |
| STI Brembo caliper mounting bolts... | SkAsphalt | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 4 | 05-13-2014 08:24 PM |
| Secondary Rear Brake Caliper for drifting or parking brake?? (pics) | Axel | Scion FR-S / Toyota 86 GT86 General Forum | 20 | 02-25-2010 11:28 AM |
