Racecomp Engineering
Old 09-17-2016, 10:54 PM   #1
86wtywly
Drives: 2014 Scion Frs
Alignment sheet explanation. Anyone?
Checked the alignment with the dealer due to the light feeling of the steering wheel. They looked at my car, checked the alignment, tire pressure and claimed that everything was ok. No problem with the steering whatsoever.
Does this alignment sheet look ok or it's better to get an alignment check at local tire shop.
Thanks.
86wtywly is offline   Reply With Quote
Old 09-17-2016, 10:56 PM   #2
gramicci101
Off Topic
Attach the sheet?
Old 09-17-2016, 10:58 PM   #3
86wtywly
Originally Posted by gramicci101 View Post
Attach the sheet?
It's on my phone. Can't upload it!
Old 09-17-2016, 11:01 PM   #4
gramicci101
Off Topic
Go to www.imgur.com and upload it. From there, you can copy the link and post it here. Or open the pic in a new tab and copy the actual image url.
Old 09-17-2016, 11:13 PM   #5
86wtywly
Attach the sheet?
Hope this works.
Old 09-17-2016, 11:13 PM   #6
86wtywly
Attach the sheet?
Second part
Old 09-17-2016, 11:15 PM   #7
86wtywly
I upload it. Could u take a look?
The Following User Says Thank You to 86wtywly For This Useful Post:
gramicci101 (09-17-2016)
Old 09-17-2016, 11:27 PM   #8
gramicci101
Off Topic
Right off the bat, your toe is fucked up, front and rear. Technically they all look to be within OEM spec, but OEM spec is a range that leaves a bit of variance, not a number. Go to a performance alignment shop and get it aligned to a number. Shoot for 0 toe in the front and slight toe-in in the rear. I'm guessing the slight toe out on the front and a lot of toe out on the rear is what's giving you the floaty feeling, but others will be able to say more than I can.
I tagged RCE; hopefully they come and offer their expertise.
Originally Posted by OEM Spec
Front:
Camber: 0 +/- 45' (0 +/- 0.75°) (Right/Left Difference: 0°45' (0.75°) or less)
Caster (Reference): 5°54' (5.90°)
Steering Axis Inclination (Reference): 15°31' (15.52°)
Toe (Each Wheel): 0°00' +/- 0°11' (0.00° +/- 0.19°)
Toe (Total): 0 +/- 3.0 mm (0 +/- 0.1181 in.)
Rear:
Camber: -1°12' +/- 45' (-1.20° +/- 0.75°) (Right/Left Difference: 45' (0.75°) or less)
Toe (Each Wheel): C + D: 0°10' +/- 0°15' (0.16° +/- 0.24°)
Toe (Total): 2.0 +/- 3.0 mm(0.0787 +/- 0.1181 in.)
Old 09-17-2016, 11:32 PM   #9
Cole (09-18-2016), e1_griego (09-17-2016), mdm (09-18-2016)
Old 09-17-2016, 11:35 PM   #10
gramicci101
Off Topic
If you're in Irvine talk with @CSG Mike as well. They're local to you, and very very experienced.
Old 09-17-2016, 11:38 PM   #11
86wtywly
Thanks for ur explanation! I will definitely go to a alignment shop to get it checked!
Old 09-17-2016, 11:40 PM   #12
86wtywly
Yea I am in Irvine. what is his shop's name?
Old 09-17-2016, 11:41 PM   #13
gramicci101
Off Topic
@CounterSpace Garage.
http://counterspacegarage.com/
Old 09-18-2016, 09:42 PM   #14
Th3rdSun
Drives: 2013 FR-S MT Hot Lava
Firestone does lifetime alignments. Pay once,and go back and get it aligned for free for as long as you own the car.
Toe angel kills tires faster than anything. You really don't want any toe angle at all for a daily driver.
Th3rdSun is offline   Reply With Quote
Spring and damper rates: front vs rear, explanation needed Ashikabi Suspension | Chassis | Brakes -- Sponsored by 949 Racing 12 03-14-2015 05:21 PM
Wheel jargon explanation please nzer Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 8 10-29-2012 05:09 AM
Exhaust parts explanation JoeBoxer Engine, Exhaust, Transmission 10 09-13-2012 08:46 PM
Explanation on the different driving modes? WatchmaN Scion FR-S / Toyota 86 GT86 General Forum 11 08-02-2012 08:36 AM
Scion's Explanation of BRZ FR-S Limited Slip Differential stalon320 Engine, Exhaust, Transmission 5 06-22-2012 12:26 PM
