Old 03-20-2017, 04:17 PM   #1
mokinbird87
BOXER FR
mokinbird87's Avatar
Drives: WRB BRZ Limited
grinding noise when accelerating from stop
[ame="https://www.youtube.com/watch?v=SHNnT-0CrOs"]March 20, 2017 - YouTube[/ame]
do you guys hear the grinding when i accelerate? Only happens in 1st gear
and only on left hand turns loading the front right wheel. the right front side has been in an accident previously and I ended up replacing the lower control arm and the hub carrier. I checked everything for any rubbing but no signs.. I even changed the driveshaft to another OEM one, but that didnt fix anything..
mokinbird87 is offline   Reply With Quote
Old 03-20-2017, 08:56 PM   #2
Mr Nerd
Mr Nerd's Avatar
Have you tried accelerating from a stop in 2nd gear? (Without lugging it too much of coarse)
Mr Nerd is offline   Reply With Quote
Old 03-20-2017, 10:57 PM   #3
Yes, I hear it ....... doesn't sound good .....
Is the crunchy sound coming from the front of the vehicle .. ??
After the accident, and they replaced the hub carrier, did they replace the bearing..?? I had to ask.
Why did you change the driveshaft ... ??
I suggest you take off the front wheels and inspect the hubs and bearings and the brake calipers.
Or, do it the humfrz way ...... take it up to a local alignment/suspension shop and let them sort it out.
OH HELL ....... daaaaa ........ I forgot ...... change the transmission oil ......
(that fixes everything)
Old 03-21-2017, 10:59 PM   #4
mokinbird87
BOXER FR
So actually I have. Verdict is it only does it when I'm turning left but not when going straight (in 2nd gear).
Old 03-22-2017, 01:31 AM   #5
Mr Nerd
Mr Nerd's Avatar
Is it possible to tell if it's coming from the front or back? I'm leaning toward a a prob with your diff/lsd. Any mods or changes recently with your rear differential? Could also have something to do with VSC and wheel speed sensors but that would be very unusual.
Old 03-22-2017, 04:00 AM   #6
mokinbird87
BOXER FR
Bearing was not changed.. I have done the transmission fluid not too long ago. I always use Motul for everything. Body shops mechanic told me he sees something weird about the driveshaft.. silly me I should've looked under myself but at $100 I was just willing to try to cancel out the possibility that it could be the driveshaft.
I do have a weird wearing pattern on the front brake pads (inside wearing much faster) and I'm missing the metal shim.. can't be this causing the issue tho?
Old 03-22-2017, 04:01 AM   #7
mokinbird87
BOXER FR
It is for sure coming from the front. I'm leaning towards overpipe hitting the crossmember due to bad engine mount or something
Old 03-22-2017, 04:07 AM   #8
Mr Nerd
Mr Nerd's Avatar
It is not the overpipe. I am 100% sure if that. This is most certainly related to low rpms and your turning plane. I honestly have no more input other than to take it to a dealer and have them evalute the car and re-calibrate the VSC. Very strange....
Old 03-22-2017, 10:27 AM   #9
Bingo!
Driveshaft wouldn't just make a noise in one gear and while turning. It is not your problem.
Old 03-22-2017, 07:32 PM   #10
mokinbird87
BOXER FR
I'll try the rebuild of calipers and put in new pads with the shims and see what happens
Old 04-07-2017, 10:59 PM   #11
mokinbird87
BOXER FR
Got whole new calipers. Figured out overpipe is rubbing against the front crossmember
Old 05-22-2021, 01:53 AM   #12
botbs
botbs's Avatar
Drives: 18 BRZ tS, 27 GRMN 86
Hi there,
How did you solve the overpipe issue?
Thanks!
botbs is offline   Reply With Quote
Old 05-26-2021, 03:10 AM   #13
Originally Posted by botbs View Post
Hi there,
Thanks!
My guess would be ..........
Tcoat (05-26-2021)
Shuddering feeling when accelerating from a stop while turning mithrandiir42 Engine, Exhaust, Transmission 3 07-24-2016 03:15 PM
Grinding noise when AC on Mikeez Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 6 07-11-2016 02:25 AM
Ticking/Clicking noise when accelerating? Pineapple Issues | Warranty | Recalls / TSB 3 08-28-2014 04:29 PM
Grinding noise? frs10 Issues | Warranty | Recalls / TSB 7 09-20-2013 11:57 AM
accelerating from a dead stop jarviz Scion FR-S / Toyota 86 GT86 General Forum 78 07-26-2012 03:11 PM
