Old 03-19-2021, 02:17 PM   #1
KR-S
Sporadic Member
KR-S's Avatar
Drives: 2016 Halo FR-S M/T
OEM horn connectors
Long story short, a while back the wiring for my horn got damaged (don't ask how, I can't even explain it) and I'm trying to see if it's worth repairing myself. I'll be ordering an oil cooler next month and so I will need to remove my front bumper, so while I'm at it, I might as well check to see if I can repair the wiring to the horn. I'm trying to figure out if I'm missing an OEM connector, or if just the wires got separated from the connectors, or if something worse has happened.
For context, I'm not running OEM horns. I have (or had) an aftermarket harness for my horns that are designed to connect to the OEM connectors on the car for plug-and-play installation.
At the moment, I only have two pictures of my issue, but I'll try to clarify some things.
These two wires were what I found, completely exposed and only wrapped up with black tape:
And this is what I believe they were previously connected to:
Name:  horn connector.jpg
Though, honestly, I'm not sure if I'm even right, hence, why I would need a picture. Would anyone happen to have an actual picture of the wires going up to their horn? I can get more pictures as needed if it will help you guys figure out what's happening.
Old 03-19-2021, 03:00 PM   #2
That's the outside temp sensor. It clips to one of the right-side radiator brackets.
KR-S (03-19-2021)
Old 03-19-2021, 04:39 PM   #3
KR-S
Sporadic Member
KR-S's Avatar
Thanks for the clarification. In that case, is the top part of the sensor supposed to be the mounting point?
Old 03-19-2021, 05:40 PM   #4
Yeah. I expect that you will find the mate still attached to the bracket.
KR-S (03-19-2021)
OEM Subaru BRZ connectors kilohercas Electronics | Audio | NAV | Infotainment 5 01-30-2018 04:08 PM
connectors not plugged in?? trexx0411 Scion FR-S / Toyota 86 GT86 General Forum 8 08-03-2015 09:00 AM
OEM Connectors taylork057 Scion FR-S / Toyota 86 GT86 General Forum 2 01-17-2014 02:00 PM
FS: litech HID's with connectors $120 ts87 Canada Classifieds 0 06-21-2013 10:37 AM
Oem amp connectors cruzinbill Electronics | Audio | NAV | Infotainment 10 01-31-2013 06:47 PM
