View Poll Results: Which suspension kit?
TRD coilover 2 20.00%
TRD Sportivo set (-1 cm) 0 0%
86 GR (-1 cm) 0 0%
BRZ tS/STi Sport 2017+ (no lowering) 4 40.00%
tS 2015/STi aftermarket Bilstein (-1.5 cm) 4 40.00%
Voters: 10. You may not vote on this poll
Old 07-14-2020, 05:35 PM   #1
gpvecchi
gpvecchi's Avatar
Suspension kit poll
I'm debated between these (and only these) option for suspensions, for street use: what do you think?
Old 07-14-2020, 06:06 PM   #2
BlueWhelan
BlueWhelan's Avatar
Drives: 2013 Blue Subaru BRZ. 6 Spd manual
for what its worth, I just put 2018 ts suspension on my 2013 BR-Z (which previously had a PP setup). The front is down almost 10mm and the rear is higher by about 5mm...
BlueWhelan is online now   Reply With Quote
The Following User Says Thank You to BlueWhelan For This Useful Post:
gpvecchi (07-15-2020)
Old 07-14-2020, 06:13 PM   #3
HaXx
Drives: jrsc_brz
which ones lower the most? id go with whatever ones lower the most. thats really the only reason to get lowering springs, right? its not like "your ride will improve" (i guess youll have a lower center of gravity, but give me a break) so i would get ones that will actually make your car look lower after you go through all the work. good choices btw
JACKSON RACING l RALLYBACKER l FORGESTAR l FORTUNE AUTO l INVIDIA
HaXx is offline   Reply With Quote
The Following User Says Thank You to HaXx For This Useful Post:
Old 07-15-2020, 12:03 PM   #4
pallen
pallen's Avatar
Drives: 2017 Toyota 86
All the lowering springs I've looked at have higher than stock spring rates, so your ride will definitely change. "improve" is subjective, but it will be different.
pallen is offline   Reply With Quote
The Following User Says Thank You to pallen For This Useful Post:
DarkPira7e (07-15-2020)
Old 07-15-2020, 03:48 PM   #5
I'd pick the do nothing option -
Old 07-15-2020, 04:13 PM   #6
gpvecchi
gpvecchi's Avatar
I'd stay with stock PP Package, if it wouldn't be so high... I'm even debated of last tS stock suspensions, as they are even higher than stock...
Old 07-15-2020, 09:32 PM   #7
norcalpb
norcalpb's Avatar
Do you have any more information on the GR suspension?
Old 07-15-2020, 10:41 PM   #8
Espi
Espi's Avatar
Drives: 17 BRZ
Long story short I'm going back to Ts 2018 Springs. Yes I was able to source another set
What happened? Swift SR springs are too stiff for daily.
What changed? Its planted on flat roads and looks very nice with Swifts. I miss the stock balanced feel and slightly loose back end from the Ts Springs. Front and Rear dropped by half inch too.
I vote 2018 Ts Springs. In the end its your car and your choice
Espi is offline   Reply With Quote
The Following 2 Users Say Thank You to Espi For This Useful Post:
gpvecchi (07-16-2020), norcalpb (07-16-2020)
Old 07-16-2020, 02:15 AM   #9
gpvecchi
gpvecchi's Avatar
Specific dampers and 1 cm lowered springs made by Chuhatsu.
The Following User Says Thank You to gpvecchi For This Useful Post:
Old 07-16-2020, 03:16 AM   #10
BlueWhelan
BlueWhelan's Avatar
The ts has dampers specific to the springs as well
Old 07-16-2020, 12:46 PM   #11
N_Raged
Drives: 2019 BRZ Sport-Tech RS
You Americans and your abundance of rare parts!
I have not been so lucky here in Canada.
N_Raged is offline   Reply With Quote
The Following User Says Thank You to N_Raged For This Useful Post:
Espi (07-16-2020)
Old 07-16-2020, 06:53 PM   #12
Espi
Espi's Avatar
Drives: 17 BRZ
Facebook marketplace my friend just keep an eye out they pop up from time to time.look for sell groups specific to the twins.
Old 07-16-2020, 07:06 PM   #13
Westen86
Purist
Westen86's Avatar
Drives: 2013 FRS - Hot Lava
Koni/Bilstein and RCE Yellows with those Pedders offset topmounts for sale in the classified right now.
WTB: Everything Verus
RaceComp SS-1, Complete SuperPro bushings, TR Motorsport FF10 17x9 +45, GruppeS UEL, HKS Hi-Power V2, OFT(93/E85)
Westen86 is offline   Reply With Quote
Old 07-17-2020, 12:42 AM   #14
HaXx
Drives: jrsc_brz
dont give me that, @Route's frs has all the craziest collector parts and hes up there with you. 14R stuff and all that OEM+ goodness.
The Following 2 Users Say Thank You to HaXx For This Useful Post:
gpvecchi (07-17-2020), Route (07-17-2020)
Rear Suspension Clunking, front suspension groaning Butterballz Suspension | Chassis | Brakes -- Sponsored by 949 Racing 5 08-14-2018 08:10 PM
Suspension Super Sale ISC Suspension | KW | Tein | Cusco and More OCRaceShop.com Brakes, Suspension, Chassis 14 08-26-2015 11:43 AM
Squeaking / Creaking rear suspension with low ride height? Suspension pros welcome! mothespaceman Suspension | Chassis | Brakes -- Sponsored by 949 Racing 10 08-14-2015 06:06 PM
The OFFICIAL Ohlins Coilover Suspension thread - High End Competition Suspension ModBargains.com Suspension | Chassis | Brakes -- Sponsored by 949 Racing 63 05-22-2013 09:15 AM
