Suspension kit poll
I'm debated between these (and only these) option for suspensions, for street use: what do you think?
for what its worth, I just put 2018 ts suspension on my 2013 BR-Z (which previously had a PP setup). The front is down almost 10mm and the rear is higher by about 5mm...
All the lowering springs I've looked at have higher than stock spring rates, so your ride will definitely change. "improve" is subjective, but it will be different.
I'd stay with stock PP Package, if it wouldn't be so high... I'm even debated of last tS stock suspensions, as they are even higher than stock...
Do you have any more information on the GR suspension?
Long story short I'm going back to Ts 2018 Springs. Yes I was able to source another set :)
What happened? Swift SR springs are too stiff for daily. What changed? Its planted on flat roads and looks very nice with Swifts. I miss the stock balanced feel and slightly loose back end from the Ts Springs. Front and Rear dropped by half inch too. I vote 2018 Ts Springs. In the end its your car and your choice :thumbsup: |
The ts has dampers specific to the springs as well
I have not been so lucky here in Canada. |
Koni/Bilstein and RCE Yellows with those Pedders offset topmounts for sale in the classified right now.
| All times are GMT -4. The time now is 10:44 PM. |
User Alert System provided by
