Old 07-14-2020, 07:04 PM   #1
chengo
Drives: 2017 BRZ
HKS V3 supercharger
Hi guys, since i have the supercharger kit on my car, the spark plugs had failed 3 times.
Just wondering is the oem plugs good enogh to handle 10 psi of boost ?
Any recommendation for some good aftermarket plugs ?
chengo is offline   Reply With Quote
Old 07-14-2020, 07:08 PM   #2
Westen86
Purist
Westen86's Avatar
Drives: 2013 FRS - Hot Lava
HKS Plugs
WTB: Everything Verus
RaceComp SS-1, Complete SuperPro bushings, TR Motorsport FF10 17x9 +45, GruppeS UEL, HKS Hi-Power V2, OFT(93/E85)
Westen86 is offline   Reply With Quote
Old 07-15-2020, 01:49 AM   #3
86TOYO2k17
Drives: 2017 toyota 86
People are running 20+ Psi and 550+ whp on stock plugs. What was wrong with yours to make them fail? HKS plugs seem pretty good though. But if they went bad for any reason other then not being up to par (which I doubt is the reason) it will probably keep happening.
The Following User Says Thank You to 86TOYO2k17 For This Useful Post:
CSG Mike (07-15-2020)
Old 07-15-2020, 03:56 PM   #4
ls1ac
ls1ac's Avatar
Need to post closeup pictures of the bad plugs. What has failed?
Old 07-16-2020, 03:06 AM   #5
jflogerzi
jflogerzi's Avatar
Agreed with others. Are they burning out or getting fouled
2013 Series 10 FRS #553
Old 07-16-2020, 05:28 PM   #6
sroby
Drives: 2015 Firestorm 08/05/15
I’d bet this is tied to tune / tune related. Follow up plsr when you get it sorted I’m curious as heck myself ��
sroby is offline   Reply With Quote
Old 07-19-2020, 01:10 AM   #7
BRZ_88
Imperator
Drives: Supercharged 2013 BRZ Limited
I have this kit installed on my car with the upgraded pulley, so a peak boost of 13 psi.
I've had no problems with the OEM spark plugs, although I am running E85 (not sure if that makes a difference?).
BRZ_88 is offline   Reply With Quote
Old 07-21-2020, 02:08 PM   #8
mrg666
pessimistic skeptic
mrg666's Avatar
That is probably a bad tune running too rich. I would get a proper retune with the new plugs.
Old 07-21-2020, 02:41 PM   #9
HuntingtonFRS
Drives: 2013 Scion FR-S in White
When I had this car and used the default tune from HKS I decided to buy the HKS spark plugs. The only reasoning I had at the time was because that’s the part they used for their testing and I trusted the brand. (And I wanted something to play with on the car)
After taking out the factory plugs I noticed they were a bit black and felt better about buying the HKS set. I am going to have to recommend you buy 5 though. After several hours of installing the plugs one of them was bad and it didn’t run right. I had to put an oem plug back in until the replacement arrived.
HuntingtonFRS is offline   Reply With Quote
sparkplugs, supercharger
HKS V3 Supercharger lunatic808 Forced Induction 1 04-07-2018 09:44 PM
HKS Supercharger GT Property Kit or HKS Supercharger V2? Ragingft86 Forced Induction 5 12-10-2016 01:59 PM
Supercharger help Scott_frs Forced Induction 2 01-16-2015 03:56 PM
HKS Supercharger Kit for FR-S & BRZ. 1660 Engine, Exhaust, Transmission 6 11-27-2012 07:11 AM
supercharger? but by who? carbonBLUE Forced Induction 14 11-02-2012 11:10 PM
