Old 08-09-2012, 04:33 PM   #1
zoomzoomers
zoomzoomers's Avatar
Anyone having this issue?
This is different from the chirpping issue during idle and I didn't see anyone else post about this so here goes...
It seems that the FA20 is quite cold blooded. Seems to take longer than other cars I've owned to get to normal operating temps. One other thing I've noticed is that when the motor is cold and I come to a stop, not a hard stop mind you, the idle fluctuates a bit and the motor looses revs like it's about to die, but never does and it's very slight. Anyone else notice this on their car? BTW, I don't seem to have the chirpping issue at idle thought.
Old 08-09-2012, 05:27 PM   #2
Draco-REX
Corner Junkie
Draco-REX's Avatar
Drives: 13 BRZ, 11 STI, 99 RS
The idle dip has been documented by many owners and there are multiple threads on it. I haven't seen it dip any more than other cars I've owned, but others have actually seen the car stall.
As for the coolant temp, I've noticed that my car seems to come up to temp really quickly, and underhood temps seem high to me. Odd. I know my thermostat is working, but I wonder if yours is stuck open...
Old 08-09-2012, 05:48 PM   #3
Jayde
Jayde's Avatar
I can only recall my engine RPM dropping to almost a stall without the AC on once. Any other time the AC was on.
And the engine warms up quite quick for me too. From sitting for ~8 hours till the gauge moving only takes a minute or so.
Jayde is offline   Reply With Quote
Old 08-09-2012, 06:22 PM   #4
zoomzoomers
I haven't read too much about motor issues with the FA20, but I didn't know that other people have experienced this issue. It's very slight, but you can definitely feel it. Strange thing is it seems to stop once the motor warms up.
Old 08-09-2012, 06:30 PM   #5
industrial
Add lightness!
industrial's Avatar
Drives: 17' WRX
I've noticed this. I thought my car was going to die one morning at a Dunkin Donuts drive through. This doesn't always seem to happen and my car has never died. I wonder if this will be a big issue in the winter?
industrial is offline   Reply With Quote
Old 08-09-2012, 07:52 PM   #6
zoomzoomers
Does it stop once your motor gets warm? Mine seems to stop once its warm.
Old 08-09-2012, 08:05 PM   #7
wu_dot_com
Drives: accord
mine happends all the time even when engine is warm. i think this is a combine effect of light flywheel and pulley that i have on.
wu_dot_com is offline   Reply With Quote
Old 08-09-2012, 08:08 PM   #8
zoomzoomers
Hahaha ok then you don't count since you've got mods. I'm referring to stock. The engine either seems starved for fuel/air/etc for a quick second and the revs die. Then back to normal like it never happened. One thing though, for me, it always happens when the motor is cold and I'm on the brakes. Otherwise, it doesn't happen even if the motor is cold.
Old 08-09-2012, 10:28 PM   #9
hyper4mance
hyper4mance's Avatar
Drives: 13 BRZ, 97 e36 M3 Rides: '07 600RR
Comming out of my garage (slight bump) in the morning it does that as well, but I let the car warm up till the rpms start dopping to ~1k and start moving. Other than that I haven't seen it drop.
hyper4mance is offline   Reply With Quote
Old 08-09-2012, 11:06 PM   #10
GoSharks
GoSharks's Avatar
Drives: BRZ Limited, WRB, 6 MT
I would have the dealer check for a stuck thermostat that maybe not closing correctly during warm up. My BRZ warms up very quickly although the transmission (MT), needs to warm up as well. When cold, i need to be real careful on 1 - 2 shifts. Linkage feels very stiff. Others have mentioned this before attributing the design. Not a big deal, but definitely there. Oh, and I have the chirping at idle too.
GoSharks is offline   Reply With Quote
Old 08-10-2012, 12:18 AM   #11
Stu L Tissimus
Stu L Tissimus's Avatar
Drives: MT GB BRZ Limited
I've had the idle dip issue and actually had it fixed by Subaru - read some of my earliest posts. It hasn't given me a problem in a month or two.
すばらしい。いや、スバルしい。
Stu L Tissimus is offline   Reply With Quote
Old 08-10-2012, 12:19 AM   #12
Skye
Drives: TR2,CooperS,BRZ
Mine warms up normally but needle doen't reach halfway, Draco how high does your needle point?
Skye is offline   Reply With Quote
iPod issue? Mr.Jay Electronics | Audio | NAV | Infotainment 12 02-10-2013 03:41 AM
Mud Guards, got them, put them on, have issue. michaelahess Cosmetic Modification (Interior/Exterior/Lighting) 14 09-11-2012 02:03 PM
Idle issue scioneric CANADA 23 08-24-2012 02:40 AM
The weight issue mickey177 Scion FR-S / Toyota 86 GT86 General Forum 24 07-27-2012 09:47 AM
Opticoat issue dav0777x Cosmetic Modification (Interior/Exterior/Lighting) 3 06-24-2012 06:42 PM
