Old 06-18-2020, 04:41 PM   #1
RWD fun
Crank but no start after clutch rep.
As the title states, my engine will turn over but not start. The only thing I can think of is the wire that comes off of the harness near the crank (it's an L shaped bracket that appears to be a ground). I cant for the life of my remember where it goes.
RWD fun is offline   Reply With Quote
Old 06-18-2020, 04:52 PM   #2
Ashikabi
Ashikabi's Avatar
If it's a ground then stick it anywhere with good metal to metal contact
Sent from my ONEPLUS A5010 using Tapatalk
Old 06-18-2020, 04:54 PM   #3
vladniko86
vladniko86's Avatar
Drives: FRS
I think the one you’re talking about goes right over the starter bolt hole and the trans/starter bolt holds it down
vladniko86 is offline   Reply With Quote
Old 06-18-2020, 05:15 PM   #4
RWD fun
I got that back on but still nothing. Also did spark plugs but coils are all back on.
Old 06-18-2020, 05:40 PM   #5
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
Make sure the DI module bolts are tight.
If you need pictures as an example let me know. I have my car handy and partially torn apart.
Old 06-18-2020, 06:16 PM   #6
RWD fun
DI mdoule?
Old 06-18-2020, 06:20 PM   #7
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
Originally Posted by RWD fun View Post
DI mdoule?
Yes, the DI driver module.
3 bolts.
Old 06-18-2020, 06:50 PM   #8
RWD fun
So my throttle body makes a humming noise as long as the key is in the "on" position. I've never noticed it before but I don't think it's normal.
Also, say I had a bad coil or plug, the car would probably start even if it was with a misfire?
Old 06-18-2020, 07:42 PM   #9
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
Bad coil or plug would misfire and likely still start. It would give you a CEL usually too.
Old 06-18-2020, 11:13 PM   #10
RWD fun
How can i check for spark? Doesn't seem practical the old school way because of the flat 4 configuration
Old 06-18-2020, 11:39 PM   #11
solidsnake11
Drives: brz
Check fuses.
Check all the elec plugs on passenger side of engine.
A few other things that will keep it from starting is intake cam sensors, direct injection fuel pressure sensor and maybe crank sensor.
I know this is stupid but did you put the crank reluctor on correct? It happens.
solidsnake11 is offline   Reply With Quote
Old 06-19-2020, 02:06 AM   #12
RWD fun
Originally Posted by solidsnake11 View Post
Check fuses.
I know this is stupid but you did put the crank reluctor on correct?
Crank reluctor? Fuses are next.
Old 06-19-2020, 07:34 AM   #13
Ashikabi
Ashikabi's Avatar
You could hook up a timing light. That'll prove spark.
Old 06-19-2020, 07:51 AM   #14
solidsnake11
Drives: brz
The ring behind the flywheel with teeth on it. It has a dowel that has to be lined up for correct crank position.
No start No crank Anti-theft blinking 02maher Issues | Warranty | Recalls / TSB 37 05-18-2020 09:00 AM
Car won't start - doesn't try to crank at all, but lights are working HELP cdo221 Issues | Warranty | Recalls / TSB 28 06-06-2018 06:30 PM
Crank No start (Not battery issue) NEED HELP cnxmist Issues | Warranty | Recalls / TSB 19 07-28-2017 05:44 AM
Car won't start, won't crank, no ecu communication redlined600 Issues | Warranty | Recalls / TSB 10 07-09-2016 12:55 PM
No crank no start issue *KID* Issues | Warranty | Recalls / TSB 3 09-29-2014 06:22 AM
