Grinding noise ?
Hey all,
While i'm driving I can hear almost an inconsistent grinding. I jacked up the front and spun the driver side wheel and recorded a clip. https://drive.google.com/file/d/14Vh...G8Urm00du/view (You can hear it better with headphones) Is this normal ? Bad brake pads ? Warped rotor ? Wheel bearing ? |
#2 |
Drives: '13 BRZ
Subscribed, I have a similar sound. Have not yet taken the brakes apart to inspect.
#3 |
The guy w/o an FRS or BRZ
Drives: '23 GR86 Premium 6MT Halo White
I had this problem on my WRX when stones get wedged between the rotor and brake dust shield. Just need to bend it back so there's clearance.
#4 | |
#5 |
[insert cool phrase here]
Drives: BRZ Premium
Normal brake noise.
If it really bothers you take off wheel, take off brake pads and use brake cleaner. . Re lube the guide pins on the calipers. If all else fails burn car, don't bother trying to fix it. Buy a brand new Honda Civic SI, spend a few more bucks on the lifetime service maintenance. You'll never have to fuck with the brakes ever again
Weekend fun/track car - '91 MR2 Turbo Gen3 Old daily driver - '88 MR2 Supercharged |
#6 |
Rust bucket enthusiast
Sounds like dirt, mud, or a stone in the brake shield as has been said here. Try pressure washing to knock it out. Could also be a small gremlin hiding in the caliper who breathes funny.
#7 |
How many miles on the car? Original brakes?
#8 |
Drives: 2017 BRZ Premium MT (DGM)
(This thread was the closest I could find to the grinding sound I describe below, any other thoughts as to what could be the issue are appreciated. Thanks.)
I have ~12500 miles on my 2017 BRZ Premium, purchased new 30 month ago. I do mostly suburban driving, few/infrequent highway miles. I'm not particularly hard on the car (e.g. it's never been tracked), but I do "drive it." Long story short, this afternoon I noticed a new "sound". I've read all the stories of rattles & creaks but this car until today has been totally solid. This (new as of today) sounds like a "grinding" or rattling noise. It's not the engine or transmission, and I can only hear it loudly when rolling to or from a stop, even in neutral, both with or w/o applying brakes, and at 15MPH<. It's not coming from the body or the interior - at first I thought maybe I picked something up, a tree branch or twig caught someplace in the wheel area or chassis, but I looked underneath and don't see anything unusual. The rotors and calipers appear free of debris. The noise appears to be coming form the left rear wheel area. Have a routine service coincidentally scheduled for tomorrow, but already dreading the "the tech checked and didn't hear anything" answer from the dealer/service manager. |
#9 |
Can you get a recording of it? If heard when slow, maybe have someone film you coasting. Just throwing out ideas.
| The Following User Says Thank You to Ultramaroon For This Useful Post: | joro2 (10-31-2019) |
#10 |
It may be a wheel bearing going bad.
![]() humfrz |
| The Following User Says Thank You to humfrz For This Useful Post: | joro2 (11-01-2019) |
#11 |
Just got a call back from the local dealer...
Good News: "We pulled a piece of metal wire out from under your chassis that was rubbing against the wheel." Problem (hopefully) solved. Bad News: $120 (!) for an oil/oil filter change and tire rotation - my first paid after the original 2 year complimentary service, not having had an out of pocket DEALER oil change in YEARS shocked by the cost <old guy shakes fist at inflation>. |
| The Following User Says Thank You to joro2 For This Useful Post: | humfrz (11-01-2019) |
#12 |
ProCrastinationConsultant
that's what you get for going to a dealership...
| The Following User Says Thank You to soundman98 For This Useful Post: | joro2 (11-02-2019) |
#13 |
Drives: Subaru BRZ
Sounds normal to me. I get this sort of thing as I don't drive my car much, surface rust on the face of the disks rubbing against the pads.
#14 |
Drives: '13 BRZ
(Copied Geex's video to YouTube for easier viewing) I finally took my caliper off and inspected my noisy brake which was the passenger front. The pads looked totally healthy at 45k. When the rotor spun past the pads at a certain spot, they made this noise. Visually everything looked fine, but with my hand I could feed that the spot on the rotor which was causing the noise had a different texture to it than the rest of the rotor face. It was almost a rough spot...pad deposit I'm assuming? So I'm guessing rotor replacement (or resurfacing) is the solution. |
| Grinding noise | alexisv1012 | Issues | Warranty | Recalls / TSB | 0 | 12-03-2018 01:18 PM |
| Grinding noise while braking | displacedTexan | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 17 | 09-01-2018 05:22 PM |
| Grinding noise when AC on | Mikeez | Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) | 6 | 07-11-2016 02:25 AM |
| clutch grinding noise | BoxerBlock88 | Engine, Exhaust, Transmission | 13 | 11-14-2015 07:12 AM |
| Grinding noise? | frs10 | Issues | Warranty | Recalls / TSB | 7 | 09-20-2013 11:57 AM |
