Old 12-08-2015, 01:05 AM   #1
Apex-Apex
Apex-Apex's Avatar
Varis 2JZ Build
November 6, 2016:
Hello,
I decided to slightly reorganize my thread since it was cluttered. I've been tracking my FRS regularly since I've owned it and modified it along the way. Unfortunately, my motor went on Oct 9, 2016 while tracking it at Buttonwillow Raceway. Though it seems a bit soon given the motor has only 35k miles, it wasn't that surprising since everyone seems to blow up these motors. I already had a 2JZ planned but I didn't expect to do it so soon. Luckily I had been collecting parts for this build but I'm still a good while from finishing it. I should have this ready by summer time and hopefully in time for 86Fest and Speed Ring.
Jason
Current Modifications (parts in red are off. Inquire if you're interested):
Exterior
  • Varis Widebody
  • Varis Kamikaze Turn Signal/Fog Delete
  • Varis Kamikaze Wiper Cowl Delete
  • Varis Kamikaze Hood Gurney
  • Varis Type 1 CF Hood
  • Jun Carbon Fiber Mirrors
  • MPH Dry Carbon Honeycomb Roof
  • MPH Dry Carbon Honeycomb Side Window
  • MPH Dry Carbon Trunk
  • Voltex Type 7 Swan Neck 1700mm Chassis Mounted
  • Aimgain Trunk Spoiler
Engine and Transmission:
  • Motec M130
  • Motec PDM 15
  • Motec C127
  • Motec Keypad
  • Rywire Engine and Chassis Harness
  • 2JZ GTE VVTI Built By DSPORT
  • CP Higher Comp Pistons
  • Carrillo H Beam Rods
  • ARP CA625 Headstuds
  • ARP Main Studs
  • King Bearings
  • Garrett GEN II GTX3576R
  • Full Race T4 Manifold
  • Twin Turbosmart Hypergate 45 Wastegate
  • Turbosmart Raceport
  • Bosch 82mm GT3 Throttle Body
  • Hypertune Wiggins Throttle Body Adapter
  • Hypertune Intake Manifold
  • Hypertune Dry Sump Oil Pan
  • OCD Works Billet Valve Cover
  • Xcessive Manufacturing Engine Mounts
  • R35 VR38 Coils
  • Titan Motorsports Dry Sump Kit
  • GSC S1 Cams
  • GSC Beehive Valvetrain
  • GSC Valves
  • GSC Valve Guides
  • Fuel Safe 10 Gallon Fuel Cell
  • Radium FCST
  • Triple Walbro 450lph E85 Pump
  • FIC 2150cc
  • Hypertune Fuel Rail
  • Turbosmart Fuel Pressure Regulator
  • Hypertune Wiggins External Pump Water Neck
  • Davies Craig External Water Pump
  • C&R Radiator
  • C&R Oil Cooler
  • T56 Magnum
  • Quicktime Adapter
  • OS GikenTriple Disk and Flywheel
  • Tilton Hydraulic Clutch Release
Footwork
  • Brembo Clubsport BBK with 355mm Type 3 Rotors
  • Brembo RE10 Compound
  • Tilton 600 Series Pedal Set
  • Advan AD08R 295/30/18
  • Volk Racing Bronze TE37 Saga
  • Racer X Fabrication Front Lower Control Arms
  • Racer X Fabrication FLCA Extenders
  • Racer X Rear Toe Arms w/ Lockout
  • JRZ RS Pro 2 Way
  • MCA Traction Mod
  • SPL Rear Lower Control Arm
  • SPL Bumpsteer Adjustable Tie Rods
  • SPL Aluminum Subframe Bushings
  • Salasko Aluminum Differential Bushings
  • Salasko Aluminum Steering Rack Bushings
  • Tomei 2 Way LSD
  • Whiteline 18mm Rear Sway Bar
  • Password JDM Rear Spherical End Links
Interior
  • Schroth 6 point HANS Hybrid
  • PCI Seat mount
  • Recaro Pro Racer HANS
  • Works Bell Steering Wheel Hub
  • Works Bell Quick Release
  • Nardi Steering Wheel 330MM Classic
  • LMR Development Roll Cage
Apex-Apex is offline   Reply With Quote
The Following 8 Users Say Thank You to Apex-Apex For This Useful Post:
Clipdat (12-15-2015), D5teph (06-17-2016), dp1 (05-25-2016), Ganthrithor (12-21-2017), irxproductions (05-27-2017), Koj (09-24-2016), Kris86 (09-08-2016), MisterSheep (12-14-2015)
Old 12-09-2015, 10:20 PM   #2
Apex-Apex
Apex-Apex's Avatar
After a week of daily driving it, I took it out to Buttonwillow to see what it felt like stock. I threw on a few supporting mods like Raceseng cam plate, Perrin oil cooler and Cusco catch can to help the car. Surprisingly, the car was pretty fun and I clocked a 2:16 6 laps in. More to come on future posts!
Just picked up a Nardi 330mm Deep Corn:
Old 12-13-2015, 02:07 PM   #3
Apex-Apex
Apex-Apex's Avatar
Latest Hyper Rev from https://www.more-japan.com/
My Nagisa rails came in from https://www.more-japan.com/ It's actually pretty cool that they used Japanese newspaper to wrap the goods. As for the rails, the quality is just as good as the Bride ones. It didn't come with resistor for the airbag but I have a few Works Bell ones laying around for that. The seat I'm using is Bride Zeta 3 off my old car and my seating position is a good 2 inches lower. I'm 5'8 and it's kind of hard to see over the steering wheel now.
Old 12-13-2015, 02:10 PM   #4
Apex-Apex
Apex-Apex's Avatar
Manhattan Beach Toyota has a listing on eBay right now for the F&R badge along with key cover for $65 to help purge the ugly Scion Badge.
The Following 4 Users Say Thank You to Apex-Apex For This Useful Post:
CxG (11-08-2016), Koj (09-24-2016), LOLS2K (12-13-2015), Mr.Impreza (05-29-2016)
Old 12-13-2015, 02:23 PM   #5
eggncheese
Drives: 2013 Ultramarine Scion FRS MT
Good stuff. I'm excited to see what else you have planned
eggncheese is offline   Reply With Quote
The Following User Says Thank You to eggncheese For This Useful Post:
Apex-Apex (12-13-2015)
Old 12-13-2015, 02:23 PM   #6
LOLS2K
/scion
LOLS2K's Avatar
Drives: '13 86 M/T
Please share link.
"Practice makes better. Only Senna is perfect." - CSG Mike
LOLS2K is offline   Reply With Quote
Old 12-13-2015, 02:46 PM   #7
Apex-Apex
Apex-Apex's Avatar
Thank you. There's isn't much coming but it'll be good parts.
Originally Posted by LOLS2K View Post
Please share link.
http://www.ebay.com/itm/321209636275...275%26_rdc%3D1
The Following User Says Thank You to Apex-Apex For This Useful Post:
LOLS2K (12-13-2015)
Old 12-13-2015, 02:49 PM   #8
LOLS2K
/scion
LOLS2K's Avatar
Drives: '13 86 M/T
Quality parts in your build BTW. Keep it up and keep us updated.
The Following User Says Thank You to LOLS2K For This Useful Post:
Old 12-14-2015, 02:38 AM   #9
Apex-Apex
Apex-Apex's Avatar
Works Bell long hub installed along with the Nardi steering wheel. There's honestly no reason to run anything other than Works Bell.
Now to wait for the shift knob and floor mats.
Old 12-14-2015, 02:12 PM   #10
MrMarinakos
Drives: Asphalt Monogram Fr-s
I like where this is going.
MrMarinakos is offline   Reply With Quote
The Following User Says Thank You to MrMarinakos For This Useful Post:
Apex-Apex (12-15-2015)
Old 12-14-2015, 03:30 PM   #11
MrDinkleman
Drives: 2016 Oceanic, "base" model
Wow. HyperRev is up to #6 for these cars??? Gotta go to J-Town...
Also, what did you do with the cruise control?
MrDinkleman is offline   Reply With Quote
Old 12-15-2015, 02:34 AM   #12
Apex-Apex
Apex-Apex's Avatar
Yeah, I didn't know until my friend showed me. I haven't figured out what to do with cruise control but since I don't use it, it hasn't bothered me.
Old 12-15-2015, 02:42 AM   #13
Apex-Apex
Apex-Apex's Avatar
Since I loved how the bronze ZE40 looked on my old car, I decided to pick up a set for the FRS.
Old 12-17-2015, 09:44 PM   #14
Apex-Apex
Apex-Apex's Avatar
Can't wait to put on the Voltex Wing! More photos on that later
Koj (09-24-2016)
Toyota GRMN 86 Concept is a Race Inspired FR-S for the Street vh_supra26 Scion FR-S / Toyota 86 GT86 General Forum 12 05-07-2016 01:49 PM
Alucard's BRZ Build alucard7755 Member's Car Journals 8 03-08-2016 03:18 PM
MINOCIN's FR-S Build, not because racecar, not because street car... just, because. MINOCIN Member's Car Journals 27 11-09-2015 12:02 AM
Street/Rally Build z3ro Member's Car Journals 3 06-07-2014 07:21 AM
C-Street BRZ 192 Build Info Sccabrz192 Tracking / Autocross / HPDE / Drifting 20 04-26-2014 11:12 AM
