Drives: Subaru BRZ
humming noise during hight speed right turns.
Hi everyone,
My car is 2013 Subaru BRZ, bought recently used. I am encountering unknown issue during high speed driving: humming noise only when turning right (even slight move of the steering wheel to the right is enough) at speeds over 110km/h- 70m/h. It can be felt as slight vibration of car body. Since then I changed the tires for new one, new tie rod ends (both), new front stabilizer links (both), setup of geometry. No change to the noise. Anyone of you had this issue in past? Any ideas? I checked the forum but could not find anything similar to this issue. Below link to video: |
#2 |
Drives: Crapcan
Front left wheel bearing/hub.
| The Following User Says Thank You to NoHaveMSG For This Useful Post: | humfrz (10-30-2020) |
#3 |
30 minute maintenance
Drives: My18 wrxsti
Definitely a symptom of a wheel bearing failing on the left side.
#4 |
Drives: Subaru BRZ
ok, than wheel bearing replacement is coming
will update after its done.
| Humming noise from head unit | jordan7831 | Electronics | Audio | NAV | Infotainment | 5 | 12-05-2017 09:43 AM |
| Fan static/humming noise | Zhangy | Issues | Warranty | Recalls / TSB | 8 | 08-26-2017 10:47 PM |
| Humming noise on left turns. | kphan | Issues | Warranty | Recalls / TSB | 10 | 10-27-2016 12:49 PM |
| Humming noise while driving | maylchi | Issues | Warranty | Recalls / TSB | 9 | 03-13-2015 02:29 AM |
| help!! weird humming noise?? | sid94 | Issues | Warranty | Recalls / TSB | 3 | 05-17-2014 01:16 PM |
