Drives: turbo frs
Hi
I have tuned online my turbo FRS The tuner told me to check how much hp now at the nearest Dyno shop ??!!! But after long tune back and forth from the tuner he told me he done More update 195hp 🤔🤔 this is the result How
#2 |
Drives: Q5 + BRZ + M796
How much boost/psi?
#3 |
Drives: UK GT86
Is that taken from a log file? Is that calculated torque from acceleration or from hp and tq values that the ECU outputs?
.: Stealth 86 :.
#4 |
Drives: 2017 toyota 86
From briefly reading other forums dynocoms typically read on the high side. 195whp on a turbo seems low for any dyno. Maybe if it’s only 7psi on pump with no other supporting mods and baseline was only 140whp then 195whp is a 40% increase.
Need more info on your setup, and did you baseline? Or at least know what other 86s baseline? |
#5 | |
Drives: turbo frs
There do one 4th gear pull to red line And this is the result I but 4+8 psi spring Total 12psi But how this could be 195 ![]() But at real driving i feel more power than this My setup Know off greedy turbo kit gt2871r Dw720 cc Emusa wastegate Stock fuel pump Online tune |
#6 |
Dismember
Drives: 2013 Red Scion FR-S
Seems low to me.
#7 |
Drives: 2013 frs red
Unless you're missing a cylinder, that dyno is screwy.
#8 |
Drives: turbo frs
#9 |
Drives: turbo frs
But I don't know why
195@7000rpm But the red line is 7800rpm!! 189@4900 Is it normal?? |
#10 |
Rust bucket enthusiast
There are a lot of parameters they could have goofed as well that could skew it badly. What elevation are you at?
#11 | |
I would confirm boost with a boost gauge. If you are at 12 psi, and the car is fast, and you still want to confirm on a dyno then try a different dyno or drag race the car.
#12 |
Drives: turbo frs
My plan is to drag race
2off my friends FRS Both I know the power This well show me my correct car power |
#13 |
Communication and people's ability to form cohearhant sentences... I weap for humanity.. but as others said go to another Dyno
Sent from my ONEPLUS A5010 using Tapatalk
2013 Series 10 FRS #553
#14 |
The dudes from OMAN and speaks Arabic... obviously a second language he’s not very good at. Still easy to get the gist of what he’s trying to say.
